- Guard most of the options in drivers/ddr/fsl/Kconfig with
SYS_FSL_DDR || SYS_FSL_MMDC.
- Migrate FSL_DMA, DDR_ECC, DDR_ECC_CMD, and ECC_INIT_VIA_DDRCONTROLLER
to Kconfig.
- Clean up the logic for including the DDR_ECC_CMD code.
CONFIG_I2C_SET_DEFAULT_BUS_NUM
CONFIG_I2C_DEFAULT_BUS_NUMBER
- As there are no boards that use different values for speed / slave on
different buses, use a single option.
- Switch to using the common SYS_I2C_SPEED / SYS_I2C_SLAVE options.
- Introduce _HAS_ options for additional buses as only the first one is
common to all users.
- Convert all remaining symbols to Kconfig.
First, we convert CONFIG_SYS_I2C_LEGACY to Kconfig. Next, as you cannot
have SYS_I2C_LEGACY and DM_I2C at the same time, introduce
CONFIG_SPL_SYS_I2C_LEGACY so that we can enable the legacy option only
in SPL. Finally, for some PowerPC cases we also need
CONFIG_TPL_SYS_I2C_LEGACY support. Convert all of the existing users to
one or more symbols.
- Rename usages of CONFIG_SYS_DEF_EEPROM_ADDR to CONFIG_SYS_I2C_EEPROM_ADDR
based on current usage.
- Convert CONFIG_SYS_I2C_EEPROM_ADDR, CONFIG_SYS_I2C_EEPROM_ADDR_LEN,
CONFIG_SYS_I2C_EEPROM_BUS, CONFIG_CONFIG_SYS_EEPROM_SIZE
CONFIG_SYS_EEPROM_PAGE_WRITE_BITS and CONFIG_SYS_EEPROM_PAGE_WRITE_DELAY_MS
to Kconfig. We move these symbols around a bit and add appropriate
dependencies to them. In some cases, we now add a correct default value
as well.
CONFIG_ID_EEPROM
The following boards no longer need CONFIG_DM_PCI_COMPAT enabled, so
remove that.
commit 0cfccb54014b ("configs: Resync with savedefconfig")
removed CONFIG_USB_STORAGE from some powerpc platforms' defconfig
files, whicih would block the use case of system loading rootfs
from USB drives, add them back.
Signed-off-by: Ran Wang <ran.wang_1@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Enable the DM ESPI driver in T1024RDB defconfig.
Signed-off-by: Xiaowei Bao <xiaowei.bao@nxp.com>
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
[Rebased]
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
Move ADDR_MAP related config options from include/configs/*.h to the
proper place in lib/Kconfig. This has been done using
./tools/moveconfig.py and manual inspection of the generated changes.
This is a preparation to use ADDR_MAP helper on ARM 32bit Raspberry Pi4
board for mapping the PCIe XHCI MMIO, which is above the 4GiB identity
mapping limit.
Enable DM_ETH on all the defconfigs for the T1024RDB board.
Signed-off-by: Madalin Bucur <madalin.bucur@oss.nxp.com>
Move below defines which are used by mtest utility to Kconfig.
CONFIG_SYS_MEMTEST_START
CONFIG_SYS_MEMTEST_END
Signed-off-by: Ashok Reddy Soma <ashok.reddy.soma@xilinx.com>
[trini: Fix kmcoge5ne board, re-run migration as well]
This enables DM_I2C and DM_RTC in T1024RDB defconfigs,
except T1024RDB SECURE_BOOT defconfig
Signed-off-by: Biwen Li <biwen.li@nxp.com>
CONFIG_PHYLIB
CONFIG_BITBANGMII
CONFIG_MV88E6352_SWITCH
CONFIG_MV88E61XX_SWITCH
CONFIG_PHYLIB_10G
CONFIG_PHY_AQUANTIA
CONFIG_PHY_ATHEROS
CONFIG_PHY_BROADCOM
CONFIG_PHY_CORTINA
CONFIG_PHY_DAVICOM
CONFIG_PHY_ET1011C
CONFIG_PHY_LXT
CONFIG_PHY_MARVELL
CONFIG_PHY_MICREL
CONFIG_PHY_NATSEMI
CONFIG_PHY_REALTEK
CONFIG_RTL8211X_PHY_FORCE_MASTER
CONFIG_PHY_SMSC
CONFIG_PHY_TERANETICS
CONFIG_PHY_TI
CONFIG_PHY_VITESSE
CONFIG_PHY_XILINX
Both symbols must be enabled when there is a raw NAND driver
selected. Also enable them when CONFIG_CMD_NAND is selected to avoid
breaking things when we'll further rework the MTD dependency
description.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
[trini: Rebase and migrate a few more boards here]
Enable eSDHC device module for T1024RDB board
Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Enable the DM PCIe driver in T1024RDB defconfig.
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Add device tree for T1024RDB board and enable CONFIG_OF_CONTROL
so that device tree can be compiled.
Update board README for device tree usage.
Move the main symbol for Freescale Fman Ethernet controller option to
Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and
rename the SPIFLASH one to follow the same format as all of the others.
To do this fully we need to migrate CONFIG_QC, do so.
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
Now that CMD_UBI does not select CMD_MTDPARTS we need to make platforms
that had been enabling it turn it on by hand. This exposed that we had
not yet migrated CMD_MTDPARTS fully, so do so now.
Fixes: 86dfa556d927 ("cmd: ubi: Remove useless call to mtdparts_init()")
The aquantia driver requires both CONFIG_PHY_GIGE and CONFIG_PHYLIB_10G.
Signed-off-by: Jeremy Gebben <jgebben@sweptlaser.com>
CONFIG_FLASH_CFI_DRIVER
CONFIG_SYS_FLASH_USE_BUFFER_WRITE
CONFIG_FLASH_CFI_MTD
CONFIG_SYS_FLASH_PROTECTION
CONFIG_SYS_FLASH_CFI
[trini: Re-migrate]
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
CONFIG_MTD_PARTITIONS
CONFIG_MTD_DEVICE
This patch moves CONFIG_MP to Kconfig
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
Migrate the CONFIG_FSL_ESDHC option to Kconfig.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
Migrate the CONFIG_BOARD_EARLY_INIT_R option to Kconfig.
Migrate the CONFIG_SYS_ALT_MEMTEST option to Kconfig.
[trini: Re-run migration after also including CMD_MEMTEST]
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
We move all instances of CONFIG_MTDIDS_DEFAULT and
CONFIG_MTDPARTS_DEFAULT from the header files to the defconfig files.
There's a few cases here where we need to expand upon what was in the
header file.
Tested-by: Adam Ford <aford173@gmail.com> #omap3_logic
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
CONFIG_ENV_IS_IN_FLASH
