path: root/configs/T1024RDB_defconfig
2017-01-04fsl_ddr: Move DDR config options to driver KconfigYork Sun
Create driver/ddr/fsl/Kconfig and move existing options. Clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com> [trini: Migrate sbc8641d, xpedite537x and MPC8536DS, run a moveconfig.py -s] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-01-04powerpc: T1024RDB: Remove macro CONFIG_T1024RDBYork Sun
Use TARGET_T1024RDB from Kconfig instead. Signed-off-by: York Sun <york.sun@nxp.com> [trini: Get missing hunk in board/freescale/t102xrdb/ddr.c] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-11-23powerpc: T1024: Remove macro CONFIG_PPC_T1024York Sun
Replace CONFIG_PPC_T1024 with ARCH_T1024 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T102xRDB: Split as T1023RDB and T1024RDBYork Sun
The defconfig files are separated. Splitting targets in Kconfig simplifies config options. Signed-off-by: York Sun <york.sun@nxp.com>
2016-10-23Convert SILENT_CONSOLE options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> [trini: Re-migrate, update common/console.c logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2015-05-04powerpc/t1023rdb: Add T1023 RDB board supportShengzhou Liu
T1023RDB is a Freescale Reference Design Board that hosts the T1023 SoC. T1023RDB board Overview ----------------------- - T1023 SoC integrating two 64-bit e5500 cores up to 1.4GHz - CoreNet fabric supporting coherent and noncoherent transactions with prioritization and bandwidth allocation - Memory: 2GB Micron MT40A512M8HX unbuffered 32-bit fixed DDR4 without ECC - Accelerator: DPAA components consist of FMan, BMan, QMan, DCE and SEC - Ethernet interfaces: - one 1G RGMII port on-board(RTL8211F PHY) - one 1G SGMII port on-board(RTL8211F PHY) - one 2.5G SGMII port on-board(AQR105 PHY) - PCIe: Two Mini-PCIe connectors on-board. - SerDes: 4 lanes up to 10.3125GHz - NOR: 128MB S29GL01GS110TFIV10 Spansion NOR Flash - NAND: 512MB S34MS04G200BFI000 Spansion NAND Flash - eSPI: 64MB S25FL512SAGMFI010 Spansion SPI flash. - USB: one Type-A USB 2.0 port with internal PHY - eSDHC: support SD/MMC card and eMMC on-board - 256Kbit M24256 I2C EEPROM - RTC: Real-time clock DS1339 on I2C bus - UART: one serial port on-board with RJ45 connector - Debugging: JTAG/COP for T1023 debugging As well updated T1024RDB to add T1023RDB. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> [York Sun: fix defconfig files] Reviewed-by: York Sun <yorksun@freescale.com>
2014-12-05powerpc/t1024rdb: Add T1024 RDB board supportShengzhou Liu
T1024RDB is a Freescale Reference Design Board that hosts the T1024 SoC. T1024RDB board Overview ----------------------- - T1024 SoC integrating two 64-bit e5500 cores up to 1.4GHz - CoreNet fabric supporting coherent and noncoherent transactions with prioritization and bandwidth allocation - 32-/64-bit DDR3L SDRAM memory controller with ECC and interleaving support - Accelerator: DPAA components consist of FMan, BMan, QMan, DCE and SEC - Ethernet interfaces: - Two 10M/100M/1G RGMII ports on-board - one 10Gbps XFI interface - PCIe: Three PCIe controllers: one PCIe Slot and two Mini-PCIe connectors. - SerDes: 4 lanes up to 10.3125GHz - IFC: 128MB NOR Flash, 512MB NAND Flash and CPLD - eSPI: 64MB N25Q512 SPI flash. - Deep Sleep power implementaion (wakeup from GPIO/Timer/Ethernet/USB) - USB: Two Type-A USB2.0 ports with internal PHY - eSDHC: Support SD, SDHC, SDXC and MMC/eMMC - I2C: Four I2C controllers - UART: Two UART serial ports Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> [York Sun: Fix ft_board_setup() type, fix MAINTAINERS for SECURE_BOOT Fix Kconfig by adding SUPPORT_SPL] Reviewed-by: York Sun <yorksun@freescale.com>
