Another shell scripting command that has not been moved.
Moved using tools/moveconfig.py using these settings:
CMD_SETEXPR bool n y
In order to reduce merge conflicts and to maintain the simplest possible
defconfig files, we should be using the savedefconfig feature of Kconfig
every time a new feature is added. This keeps the defconfig settings to
a minimum (only those things not default) and keeps them in the same
order as the Kconfig options.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
T1023RDB is a Freescale Reference Design Board that hosts the T1023 SoC.
T1023RDB board Overview
- T1023 SoC integrating two 64-bit e5500 cores up to 1.4GHz
- CoreNet fabric supporting coherent and noncoherent transactions with
prioritization and bandwidth allocation
- Memory: 2GB Micron MT40A512M8HX unbuffered 32-bit fixed DDR4 without ECC
- Accelerator: DPAA components consist of FMan, BMan, QMan, DCE and SEC
- Ethernet interfaces:
- one 1G RGMII port on-board(RTL8211F PHY)
- one 1G SGMII port on-board(RTL8211F PHY)
- one 2.5G SGMII port on-board(AQR105 PHY)
- PCIe: Two Mini-PCIe connectors on-board.
- SerDes: 4 lanes up to 10.3125GHz
- NOR: 128MB S29GL01GS110TFIV10 Spansion NOR Flash
- NAND: 512MB S34MS04G200BFI000 Spansion NAND Flash
- eSPI: 64MB S25FL512SAGMFI010 Spansion SPI flash.
- USB: one Type-A USB 2.0 port with internal PHY
- eSDHC: support SD/MMC card and eMMC on-board
- 256Kbit M24256 I2C EEPROM
- RTC: Real-time clock DS1339 on I2C bus
- UART: one serial port on-board with RJ45 connector
- Debugging: JTAG/COP for T1023 debugging
As well updated T1024RDB to add T1023RDB.
Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com>
[York Sun: fix defconfig files]
Reviewed-by: York Sun <yorksun@freescale.com>
T1024RDB is a Freescale Reference Design Board that hosts the T1024 SoC.
T1024RDB board Overview
- T1024 SoC integrating two 64-bit e5500 cores up to 1.4GHz
- 32-/64-bit DDR3L SDRAM memory controller with ECC and interleaving support
- Two 10M/100M/1G RGMII ports on-board
- one 10Gbps XFI interface
- PCIe: Three PCIe controllers: one PCIe Slot and two Mini-PCIe connectors.
- IFC: 128MB NOR Flash, 512MB NAND Flash and CPLD
- eSPI: 64MB N25Q512 SPI flash.
- Deep Sleep power implementaion (wakeup from GPIO/Timer/Ethernet/USB)
- USB: Two Type-A USB2.0 ports with internal PHY
- eSDHC: Support SD, SDHC, SDXC and MMC/eMMC
- I2C: Four I2C controllers
- UART: Two UART serial ports
[York Sun: Fix ft_board_setup() type, fix MAINTAINERS for SECURE_BOOT
Fix Kconfig by adding SUPPORT_SPL]
