path: root/configs/T1024QDS_SDCARD_defconfig
2014-12-05powerpc/t1024qds: Add T1024 QDS board supportShengzhou Liu
T1024QDS is a high-performance computing evaluation, development and test platform for T1024 QorIQ Power Architecture processor. T1024QDS board Overview ----------------------- - T1024 SoC integrating two 64-bit e5500 cores up to 1.4GHz - CoreNet fabric supporting coherent and noncoherent transactions with prioritization and bandwidth allocation - 32-/64-bit DDR3L/DDR4 SDRAM memory controller with ECC and interleaving support - Accelerator: DPAA components consist of FMan, BMan, QMan, DCE and SEC - Ethernet interfaces: - Two 10M/100M/1G RGMII ports on-board - Three 1G/2.5Gbps SGMII ports - Four 1Gbps QSGMII ports - one 10Gbps XFI or 10Base-KR interface - SerDes: 4 lanes up to 10.3125GHz Supporting SGMII/QSGMII, XFI, PCIe, SATA and Aurora - PCIe: Three PCI Express controllers with five PCIe slots. - IFC: 128MB NOR Flash, 2GB NAND Flash, PromJet debug port and Qixis FPGA - Video: DIU supports video up to 1280x1024x32 bpp. - Chrontel CH7201 for HDMI connection. - TI DS90C387R for direct LCD connection. - Raw (not encoded) video connector for testing or other encoders. - QUICC Engine block - 32-bit RISC controller for flexible support of the communications peripherals - Serial DMA channel for receive and transmit on all serial channels - Two universal communication controllers, supporting TDM, HDLC, and UART - Deep Sleep power implementaion (wakeup from GPIO/Timer/Ethernet/USB) - eSPI: Three SPI flash devices. - SATA: one SATA 2.O. - USB: Two USB2.0 ports with internal PHY (one Type-A + one micro Type mini-AB) - eSDHC: Support SD, SDHC, SDXC and MMC/eMMC. - I2C: Four I2C controllers. - UART: Two UART on board. Signed-off-by: Shengzhou Liu <Shengzhou.Liu@freescale.com> [York Sun: Fix ft_board_setup() type, fix MAINTAINERS for SECURE_BOOT Fix Kconfig by adding SUPPORT_SPL] Reviewed-by: York Sun <yorksun@freescale.com>
