path: root/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig
2016-10-23Convert SILENT_CONSOLE options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> [trini: Re-migrate, update common/console.c logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-16Move existing use of CONFIG_SPL_RSA to KconfigSimon Glass
A few boards define this in a header file which is incorrect. It means that Kconfig options that rely on this cannot be used. Move it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-14freescale: Remove CONFIG_DM from header filesSimon Glass
Kconfig options must defined in the defconfig files. Since RSA_SOFTWARE_EXP relies on CONFIG_DM, unless it is set in kconfig we cannot enable RSA. Remove the hacks which enable CONFIG_DM in header files and update the defconfig. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-01powerpc/defconfig: Rename defconfig file for T1040QDS/T1024QDS DDR4 targetsYork Sun
Previously the DDR4 targets were named with _D4. Rename them with _DDR4 for easy identification. Signed-off-by: York Sun <yorksun@freescale.com>
