path: root/configs/T1024QDS_DDR4_SECURE_BOOT_defconfig
2017-10-30configs: Resync with savedefconfigTom Rini
2017-01-04fsl_ddr: Move DDR config options to driver KconfigYork Sun
Create driver/ddr/fsl/Kconfig and move existing options. Clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com> [trini: Migrate sbc8641d, xpedite537x and MPC8536DS, run a moveconfig.py -s] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-12-02powerpc: mpc85xx: Move SECURE_BOOT to KconfigYork Sun
Move from CONFIG_SYS_EXTRA_OPTIONS to Kconfig option. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1024: Remove macro CONFIG_PPC_T1024York Sun
Replace CONFIG_PPC_T1024 with ARCH_T1024 in Kconfig and clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com>
2016-11-23powerpc: T1024QDS: Rename Kconfig option to match the nameYork Sun
Rename TARGET_T102XQDS to TARGET_T1024QDS to match the name. Signed-off-by: York Sun <york.sun@nxp.com>
2016-10-23Convert SILENT_CONSOLE options to KconfigSimon Glass
Move these option to Kconfig and tidy up existing uses. The Power PC boards don't have a suitable common element: the common header files don't appear to line up with the Kconfig files as far as I can tell. This results in a lot of defconfig changes. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jteki@openedev.com> [trini: Re-migrate, update common/console.c logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-09-16Move existing use of CONFIG_SPL_RSA to KconfigSimon Glass
A few boards define this in a header file which is incorrect. It means that Kconfig options that rely on this cannot be used. Move it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-14freescale: Remove CONFIG_DM from header filesSimon Glass
Kconfig options must defined in the defconfig files. Since RSA_SOFTWARE_EXP relies on CONFIG_DM, unless it is set in kconfig we cannot enable RSA. Remove the hacks which enable CONFIG_DM in header files and update the defconfig. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-09-01powerpc/defconfig: Rename defconfig file for T1040QDS/T1024QDS DDR4 targetsYork Sun
Previously the DDR4 targets were named with _D4. Rename them with _DDR4 for easy identification. Signed-off-by: York Sun <yorksun@freescale.com>
