Onc of key blocker for using USB Generic host controller
drivers in Allwinner are CLK and RESET drivers, now these
available for USB usage.
So switch sunxi USB use EHCI and OHCI Generic controllers.
Enabling USB is wisely a board choise, So Enable USB_OHCI_HCD
where it already have USB_EHCI_HCD
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot
could load distro images that usually get shipped as iso images. These images
usually come with a board agnostic boot environment.
However, there is very little point in having ISO support enabled (for anyone
really) in SPL, as the whole idea of SPL is to load U-Boot proper which again
is board specific. So the fact that we enable ISO support in U-Boot proper does
not mean at all that we want ISO support in U-Boot SPL.
Hence, let's remove the Kconfig dependency. Along the way, let's also clean up
all those default configs that disabled SPL ISO support.
Commit 278b90ce786f ("configs: Migrate CONFIG_SYS_TEXT_BASE") made
CONFIG_SYS_TEXT_BASE a proper Kconfig variable, with the consequence
of moving the common definition shared by almost every sunxi board
into 123 individual defconfig files. But the U-Boot start address
for Allwinner boards is a platform decision which has been around for
ages, so defining it in each *board* config file seems a bit over the
top.
Define the standard values (160MB into DRAM for most SoCs, with two
SoC exceptions) if ARCH_SUNXI is selected, and delete the lines from
the individual defconfigs.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Reviewed-by: Jagan Teki <jagan@openedev.com>
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
cmd/Makefile has:
ifdef CONFIG_FPGA
obj-$(CONFIG_CMD_FPGA) += fpga.o
endif
which means that if CONFIG_FPGA is not set, CONFIG_CMD_FPGA silently
does nothing. Let's remove that Makefile conditional and instead express
this equivalent dependency in Kconfig, so a lot of redundant
# CONFIG_CMD_FPGA is not set
can be removed from board defconfigs that don't actually have an FPGA.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
The upstream (Linux) device tree file for the Bananapi M3 follows the
convention of using the well known brand name, instead of the vendor
name, for naming. The file was recently added to upstream in commit
359b5a1e1c2d ("ARM: sun8i: a83t: Add device tree for Sinovoip Bananapi
BPI-M3")
Rename the device tree file in U-boot to match.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
This syncs all of the currently Kconfig'd symbols out of the headers and
into the defconfig files. This has two exceptions, first am335x_evm
needs to be converted to DM in SPL and then it can stop undef'ing
CONFIG_DM_USB. Leaving this as-is results in a build failure, and
without work, run time failure. The other case is am43xx_evm.h and in
turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB
host mode in SPL, but still desire to have gadget mode in U-Boot proper.
Add CONFIG_MMC_SUNXI_SLOT_EXTRA=2 to use eMMC on
BPI_M3 board.
Cc: Chen-Yu Tsai <wens@csie.org>
Cc: Maxime Ripard <maxime.ripard@free-electrons.com>
Tested-by: Jagan Teki <jagan@amarulasolutions.com>
Convert the CONFIG_SATAPWR into kconfig.
Thanks to that, many SYS_EXTRA_OPTIONS can be removed from some
defconfigs.
Signed-off-by: Mylène Josserand <mylene.josserand@free-electrons.com>
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
CONFIG_SYS_CONSOLE_IS_IN_ENV
CONFIG_CONSOLE_MUX
[trini: Re-order, re-migrate]
Move the SPL settings into common/spl where most of the SPL code is kept.
Recently a set of CONFIG_CMD_FOO defines was moved from being defined
in config_distro_defaults to Kconfig, and added to all sunxi defconfigs
to compensate.
Instead of explictly selecting these in all sunxi defconfigs,
simply always select these for sunxi boards. This makes the defconfigs
simpler and ensures a consistent set of available commands across all
sunxi boards.
The SW output of the PMIC supplies the ethernet PHY with power.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
DLDO3 is used to provide Port-D power and PD is used for the
usb-hub / sata-5v enable pins. The 2.5V comes from the schematic
and matches the factory image fex file.
The dts changes are the minimal changes needed for u-boot to
pick-up the usb host controllers. The upstream kernel does not
(yet) have usb host support.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
This is the value used in the fex file of the manufacturer images,
and also the DCDC1 default. Sometimes lower values are used to save
battery power, but that does not apply to a SBC.
Kconfig default settings are same as mentioned Sinovoip
Bpi-m3 schematic.
As axp818 ALDO support is enabled, it causes bpi-m3 fail to boot
if ALDOs are set to 0.
Signed-off-by: Vishnu Patekar <vishnupatekar0510@gmail.com>
Acked-by: Hans de Goede <hdegoede@redhat.com>
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
Add dts and defconfig for Banana-pi M3 board.
It has 2G LPDDR3, UART, ethernet, USB, HDMI, USB Sata, MIPI DSI,
mic, AP6212 Wifi, etc on it.
It is paired with AXP813 PMIC which is almost same as AXP818.
[hdegoede@redhat.com: rename to Sinovoip_BPI_M3_defconfig/sun8i-a83t-sinovoip-bpi-m3.dts]
