path: root/configs/Sinovoip_BPI_M2_defconfig
2015-12-10sunxi: select SYS_NS16550 from KconfigHans de Goede
Select SYS_NS16550 from Kconfig instead of setting it in all our defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-10-20sunxi: Add defconfig for the Sinovoip BPI-M2 boardHans de Goede
The Sinovoip BPI-M2 is a SBC board based on the A31s SoC it features 1G RAM, a microsd slot, Gbit ethernet, 4 usb-a USB-2 ports, ir receiver, stereo headphone jack and hdmi video output. The dts changes are identical to the dts files submitted upstream. A few notes on the use if dldo and aldo regulators. DLDO1 is used for Vdd for the ethernet phy, ALDO2 is used for AVdd for the ethernet phy. ALDO1 is used to power the sdio wifi module. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
