Now that those common Allwinner config symbols are defined automatically
for all boards in their Kconfig files, we can remove the now redundant
definitions from the boards' _defconfig files.
Some boards had a differing definiton for some of those symbols, it
looks like mostly to "merge races" when the symbol was introduced (new
board *_defconfig file missed the "add symbol to all files" patch).
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
Acked-by: Maxime Ripard <mripard@kernel.org>
Tested-by: Jagan Teki <jagan@amarulasolutions.com> # Amarula A64-Relic
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
The choice of the SPL_TEXT_BASE is not really a decision that should be
specified by each board's defconfig, as this setting is actually
dictated by the SoC's memory map and the BootROM behaviour.
To make this obvious and reduce the clutter in the defconfig files,
let's specify the SoC constraints in the Kconfig stanza.
This allows us to remove these lines from the defconfig files again.
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
Onc of key blocker for using USB Generic host controller
drivers in Allwinner are CLK and RESET drivers, now these
available for USB usage.
So switch sunxi USB use EHCI and OHCI Generic controllers.
Enabling USB is wisely a board choise, So Enable USB_OHCI_HCD
where it already have USB_EHCI_HCD
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
Convert USB fastboot code to use shared fastboot protocol.
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot
could load distro images that usually get shipped as iso images. These images
usually come with a board agnostic boot environment.
However, there is very little point in having ISO support enabled (for anyone
really) in SPL, as the whole idea of SPL is to load U-Boot proper which again
is board specific. So the fact that we enable ISO support in U-Boot proper does
not mean at all that we want ISO support in U-Boot SPL.
Hence, let's remove the Kconfig dependency. Along the way, let's also clean up
all those default configs that disabled SPL ISO support.
CONFIG_CONS_INDEX
We have existing entries for this option in a number of places, with
different guards on them. They're also sometimes used for things not
directly inside of the serial driver. First, introduce a new symbol to
guard the use of CONFIG_CONS_INDEX, so that in the case where we don't
need this for the serial driver, but for some other use, we can still do
it. Next, consolidate all of these into the single entry in
drivers/serial/Kconfig. Finally, introduce CONS_INDEX_[023456] so that
we can imply a correct value here to make the defconfig side of this
smaller.
[trini: Rework a lot of the logic here, such that I took authorship from
Adam, but kept his S-o-B line]
Commit 278b90ce786f ("configs: Migrate CONFIG_SYS_TEXT_BASE") made
CONFIG_SYS_TEXT_BASE a proper Kconfig variable, with the consequence
of moving the common definition shared by almost every sunxi board
into 123 individual defconfig files. But the U-Boot start address
for Allwinner boards is a platform decision which has been around for
ages, so defining it in each *board* config file seems a bit over the
top.
Define the standard values (160MB into DRAM for most SoCs, with two
SoC exceptions) if ARCH_SUNXI is selected, and delete the lines from
the individual defconfigs.
Reviewed-by: Jagan Teki <jagan@openedev.com>
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
cmd/Makefile has:
ifdef CONFIG_FPGA
obj-$(CONFIG_CMD_FPGA) += fpga.o
endif
which means that if CONFIG_FPGA is not set, CONFIG_CMD_FPGA silently
does nothing. Let's remove that Makefile conditional and instead express
this equivalent dependency in Kconfig, so a lot of redundant
# CONFIG_CMD_FPGA is not set
can be removed from board defconfigs that don't actually have an FPGA.
This commit moves USB_FUNCTION_MASS_STORAGE config to Kconfig.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
Now FASTBOOT_FLASH is auto select for sunxi platform,
so drop explicit addition.
Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
The current code, if there's both an eMMC and an MMC slot available on the
board, will swap the MMC indices based on whether we booted from the eMMC
or the MMC. This way, the MMC we're supposed to boot on will always have
the index 0.
However, this causes various issues, for example when using other
components that base their behaviour on the MMC index, such as fastboot.
Let's remove that hack, and take the opposite approach. The MMC will always
have the same index, but the bootcmd will pick the same device than the one
we booted from. This is done through the introduction of the mmc_bootdev
environment variable that will be filled by the board code based on the
boot device informations we can get from the SoC.
In order to not introduce regressions, we also need to adjust the fastboot
MMC device and the environment device in order to set it to the eMMC, over
the MMC, like it used to be the case.
Tested-by: Chen-Yu Tsai <wens@csie.org>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Fastboot need a bunch of options to be operating properly, such as the
g_dnl gadget, the fastboot command, and some options that make sense. Since
fastboot is now part of Kconfig, make sure we have them right.
That will also reduce the boilerplate in the defconfigs.
Reviewed-by: Łukasz Majewski <lukma@denx.de>
A good number of our boards have USB_GADGET enabled. Imply it so that all
the boards can benefit from it, and remove some boilerplate from our
defconfigs.
All the Allwinner boards use the same manufacturer, VID and PID for the
gadgets. Make them the defaults to remove some boilerplate from our
defconfigs.
The g_dnl USB settings for the vendor ID, product ID and manufacturer are
actually common settings that can and should be shared by all the gadgets.
Make them common by renaming them, and convert all the users.
Reviewed-by: Lukasz Majewski <lukma@denx.de>
- Move ANDROID_IMAGE_SUPPORT to top level Kconfig under images as it's
not strictly part of fastboot.
- Add some defaults for the fastboot buffer location and size
- Migrate all options listed in cmd/fastboot/Kconfig
- Cleanup the README
This syncs all of the currently Kconfig'd symbols out of the headers and
into the defconfig files. This has two exceptions, first am335x_evm
needs to be converted to DM in SPL and then it can stop undef'ing
CONFIG_DM_USB. Leaving this as-is results in a build failure, and
without work, run time failure. The other case is am43xx_evm.h and in
turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB
host mode in SPL, but still desire to have gadget mode in U-Boot proper.
On the A33, uart0 is muxed on the PB pins. On SBCs these pins may be
available for use. Such is the case on the Sinlinx SinA33.
Set CONS_INDEX=1 to use uart0 as the console, matching the device tree.
Fixes: 7095f8641863 ("sunxi: Convert CONS_INDEX to Kconfig")
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
We convert CONFIG_PARTITION_UUIDS to Kconfig first. But in order to cleanly
update all of the config files we must also update CMD_PART and CMD_GPT to also
be in Kconfig in order to avoid complex logic elsewhere to update all of the
config files.
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
The SinA33 comes with an optional 7" display. Enable it in the
configuration.
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
The SinA33 has an 4GB Toshiba eMMC connected to the MMC2 controller.
Enable it.
Reviewed-by: Chen-Yu Tsai <wens@csie.org>
Introduce a hidden USB_FUNCTION_DFU Kconfig option and select it for
CMD_DFU (as we must have the DFU command enabled to do anything DFU).
Make all of the entries in drivers/dfu/Kconfig depend on CMD_DFU and add
options for all of the back end choices that DFU can make use of.
Cc: Lukasz Majewski <l.majewski@samsung.com>
Acked-by: Lukasz Majewski <l.majewski@samsung.com>
Sinlinx SinA33 has a USB OTG port, but VBUS is controlled manually from
a jumper pad.
Enable OTG in gadget mode, as well as the download gadget and related
functions.
Sinlinx SinA33 has 1 USB host port. Enable EHCI_HCD support for it.
Also enable USB mass storage support so we can access USB sticks.
Sinlinx SinA33 uses PB4 for mmc0 card detect.
Recently a set of CONFIG_CMD_FOO defines was moved from being defined
in config_distro_defaults to Kconfig, and added to all sunxi defconfigs
to compensate.
Instead of explictly selecting these in all sunxi defconfigs,
simply always select these for sunxi boards. This makes the defconfigs
simpler and ensures a consistent set of available commands across all
sunxi boards.
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
We have CONFIG_CMD_GPIO=y in almost all sunxi boards, but after
its Kconfig conversion it has ended up missing on some recently
added boards.
Simply select it for ARCH_SUNXI, so that we get it on all
sunxi boards for both a consistent user experience and simpler
defconfig files.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
Always select OF_BOARD_SETUP on sunxi, rather then having it in almost
all our defconfigs. This also fixes it missing from some recently
added defconfigs.
This commit also modifies our ft_board_setup() to not cause warnings
when CONFIG_VIDEO_DT_SIMPLEFB is not set, since we will now always
build it.
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
Select SYS_NS16550 from Kconfig instead of setting it in all our
defconfig files.
