path: root/configs/Sinlinx_SinA33_defconfig
2016-03-23sunxi: Select CONFIG_OF_BOARD_SETUP from arch/arm/KconfigHans de Goede
Always select OF_BOARD_SETUP on sunxi, rather then having it in almost all our defconfigs. This also fixes it missing from some recently added defconfigs. This commit also modifies our ft_board_setup() to not cause warnings when CONFIG_VIDEO_DT_SIMPLEFB is not set, since we will now always build it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-12-10sunxi: select SYS_NS16550 from KconfigHans de Goede
Select SYS_NS16550 from Kconfig instead of setting it in all our defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-10-20sunxi: power: Change A23/A33 aldo1 default voltage to 3.0VHans de Goede
On A23 / A33 boards aldo1 is used for VCC-IO and should be 3.0V, make this the default. Note that this does not cause any functional changes since all sun8i board defconfig-s already contained: CONFIG_AXP_ALDO1_VOLT=3000 . Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-10-20sunxi: power: Make all voltages configurable through KconfigHans de Goede
On boards with axp221/223 pmic-s we already allow configuring most voltages. Make the Kconfig options for these also apply to boards with axp152 / axp209 pmic-s and extend them to configure all voltages. The Kconfig defaults are chosen so that this commit does not introduce any functional changes. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-07-05sunxi: Add Sinlinx SinA33 defconfigChen-Yu Tsai
Sinlinx SinA33 is a core/daughter board SDK kit from Sinlinx. It has the A33 SoC, USB host, USB OTG, audio input/output, LCD, camera, SDIO and GPIO headers. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
