path: root/configs/SBx81LIFXCAT_defconfig
2018-08-07configs: Resync with savedefconfigTom Rini
2018-08-07ARM: kirkwood: add SBx81LIFXCAT boardChris Packham
This is a series of line cards for Allied Telesis's SBx8100 chassis switch. The CPU block is common to the SBx81GP24 and SBx81GT24 cards cards collectively referred to as SBx81LIFXCAT in u-boot. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
