path: root/configs/SBx81LIFKW_defconfig
2020-08-23Convert CONFIG_NETCONSOLE to KconfigTom Rini
This converts the following to Kconfig: CONFIG_NETCONSOLE Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-28Convert CONFIG_ENV_OVERWRITE to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ENV_OVERWRITE Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rerun migration, remove some comments] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-28configs: Resync with savedefconfigTom Rini
2020-05-15rename symbol: CONFIG_KIRKWOOD -> CONFIG_ARCH_KIRKWOODTrevor Woerner
Have this symbol follow the pattern of all other such symbols. This patch also removes a TODO from the code. Reviewed-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Trevor Woerner <twoerner@gmail.com>
2020-04-28configs: Resync with savedefconfigTom Rini
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD is compiled when there is a SPI NOR flash using MTDMiquel Raynal
MTD must be enabled when there is a SPI NOR flash using the SPI_FLASH_MTD config entry. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-07configs: Resync with savedefconfigTom Rini
2019-08-25Convert CONFIG_ARCH_CPU_INIT to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ARCH_CPU_INIT Signed-off-by: Adam Ford <aford173@gmail.com> Acked-by: Chris Packham <chris.packham@alliedtelesis.co.nz> Tested-by: Felix Brack <fb@ltec.ch>
2019-08-12ARM: configs: Enable DM_ETH for SBx81LIFKW and SBx81LIFXCATChris Packham
The mvgbe driver supports DM_ETH so switch these boards to using it. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2019-05-18CONFIG_SYS_[DI]CACHE_OFF: convert to KconfigTrevor Woerner
CONFIG_SYS_[DI]CACHE_OFF had been partially converted to Kconfig parameters; only for the ARC architecture. This patch turns these two parameters into Kconfig items everywhere else they are found. All of the include/configs/* and defconfig changes in this patch are for arm machines only. The Kconfig changes for arc, nds32, riscv, and xtensa have been included since these symbols are found in code under arch/{arc,nds32,riscv,xtensa}, however, no currently-defined include/configs/* or defconfigs for these architectures exist which include these symbols. These results have been confirmed with tools/moveconfig.py. Acked-by: Alexey Brodkin <abrodkin@snopsys.com> Signed-off-by: Trevor Woerner <trevor@toganlabs.com> [trini: Re-migrate for a few more boards] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-03-25Convert CONFIG_ENV_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ CONFIG_ENV_SPI_MODE Most of time these value are not needed, CONFIG_SF_DEFAULT with same value is used, so I introduced CONFIG_USE_ENV_SPI_* to force the associated value for the environment. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-11-30arm: kirkwood: configs: Convert Allied Telesis boards to DM_SPIChris Packham
Enable CONFIG_DM_SPI=y and CONFIG_DM_SPI_FLASH=y in the defconfig. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2018-08-07configs: kirkwood: Move RTC_MV to DM and KconfigChris Packham
Now that there is DM support in the RTC_MV driver update board configs to use it. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-06-05ARM: kirkwood: SBx81LIFKW: Enable network hardwareChris Packham
The SBx81LIFKW boards connect to the internal chassis management network via a Marvell 88e6097 L2 switch. The chassis connections are direct serdes on ports 8 and 9 with a RGMII interface on port 10 connected to the CPU MAC. For debugging purposes ports 0 and 1 are also taken out to headers on the board. Because the debug interfaces are sometimes connected to with straight ribbon cables we need to run them at 10Mbps. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2018-06-05ARM: add SBx81LIFKW boardChris Packham
This is a series of line cards for Allied Telesis's SBx8100 chassis switch. The CPU block is common to the SBx81GS24a, SBx81XS6, SBx81XS16 and SBx81GT40 cards collectively referred to as SBx81LIFKW in u-boot. Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
