path: root/configs/SBx81LIFKW_defconfig
2018-08-07configs: kirkwood: Move RTC_MV to DM and KconfigChris Packham
Now that there is DM support in the RTC_MV driver update board configs to use it. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2018-06-05ARM: kirkwood: SBx81LIFKW: Enable network hardwareChris Packham
The SBx81LIFKW boards connect to the internal chassis management network via a Marvell 88e6097 L2 switch. The chassis connections are direct serdes on ports 8 and 9 with a RGMII interface on port 10 connected to the CPU MAC. For debugging purposes ports 0 and 1 are also taken out to headers on the board. Because the debug interfaces are sometimes connected to with straight ribbon cables we need to run them at 10Mbps. Signed-off-by: Chris Packham <judge.packham@gmail.com> Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Stefan Roese <sr@denx.de>
2018-06-05ARM: add SBx81LIFKW boardChris Packham
This is a series of line cards for Allied Telesis's SBx8100 chassis switch. The CPU block is common to the SBx81GS24a, SBx81XS6, SBx81XS16 and SBx81GT40 cards collectively referred to as SBx81LIFKW in u-boot. Reviewed-by: Stefan Roese <sr@denx.de> Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
