path: root/configs/PPChameleonEVB_ME_25_defconfig
2015-01-23powerpc: ppc4xx: remove PPChameleonEVB, CATcenter boardsMasahiro Yamada
These boards are still non-generic boards. It is a good thing that we can drop board-specific hack code from drivers/mtd/nand/nand_base.c Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stefan Roese <sr@denx.de> Cc: Andrea "llandre" Marson <andrea.marson@dave-tech.it>
