path: root/configs/P5040DS_SECURE_BOOT_defconfig
2015-01-16powerpc/mpc85xx: SECURE BOOT- Add secure boot target for P5040DSgaurav rana
Secure boot target is added for P5040DS platform. Signed-off-by: Gaurav Rana <gaurav.rana@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
