path: root/configs/P5020DS_SRIO_PCIE_BOOT_defconfig
2019-05-26configs: Migrate CONFIG_FMAN_ENET and some related options to KconfigTom Rini
Move the main symbol for Freescale Fman Ethernet controller option to Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and rename the SPIFLASH one to follow the same format as all of the others. To do this fully we need to migrate CONFIG_QC, do so. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-25Convert CONFIG_ENV_IS_IN_REMOTE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_ENV_IS_IN_REMOTE Signed-off-by: Simon Glass <sjg@chromium.org>
