path: root/configs/P5020DS_NAND_SECURE_BOOT_defconfig
2016-03-14freescale: Remove CONFIG_DM from header filesSimon Glass
Kconfig options must defined in the defconfig files. Since RSA_SOFTWARE_EXP relies on CONFIG_DM, unless it is set in kconfig we cannot enable RSA. Remove the hacks which enable CONFIG_DM in header files and update the defconfig. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-21Tidy up some defconfig filesSimon Glass
Several files are out of order. This means that when the moveconfig tool moves CONFIG options to Kconfig it generates a large diff. To avoid this, reorder the files first. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-07-31powerpc/mpc85xx: SECURE BOOT- NAND secure boot target for P5020 and P5040Aneesh Bansal
Secure Boot Target is added for NAND for P5020 and P5040. The Secure boot target has already been added for P3041 by enabling CONFIG_SYS_RAMBOOT and configuring CPC as SRAM. The targets for P5020 and P5040 are added in the same manner. Signed-off-by: Saksham Jain <saksham@freescale.com> Signed-off-by: Ruchika Gupta <ruchika.gupta@freescale.com> Signed-off-by: Aneesh Bansal <aneesh.bansal@freescale.com> Reviewed-by: York Sun <yorksun@freescale.com>
