path: root/configs/P2041RDB_NAND_defconfig
2020-10-05configs: Resync with savedefconfigTom Rini
2020-09-24configs: powerpc: add usb (host) mass storage supportRan Wang
commit 0cfccb54014b ("configs: Resync with savedefconfig") removed CONFIG_USB_STORAGE from some powerpc platforms' defconfig files, whicih would block the use case of system loading rootfs from USB drives, add them back. Signed-off-by: Ran Wang <ran.wang_1@nxp.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-09-24configs: P2041RDB: Enable ESPI driverXiaowei Bao
Enable the DM ESPI driver in P2041RDB defconfig. Signed-off-by: Xiaowei Bao <xiaowei.bao@nxp.com> Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-07-28Convert CONFIG_ENV_OVERWRITE to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ENV_OVERWRITE Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rerun migration, remove some comments] Signed-off-by: Tom Rini <trini@konsulko.com>
2020-07-28configs: Resync with savedefconfigTom Rini
2020-07-10powerpc: move ADDR_MAP to KconfigMarek Szyprowski
Move ADDR_MAP related config options from include/configs/*.h to the proper place in lib/Kconfig. This has been done using ./tools/moveconfig.py and manual inspection of the generated changes. This is a preparation to use ADDR_MAP helper on ARM 32bit Raspberry Pi4 board for mapping the PCIe XHCI MMIO, which is above the 4GiB identity mapping limit. Signed-off-by: Marek Szyprowski <m.szyprowski@samsung.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2020-06-04configs: enable DM_ETH support for P2041RDBMadalin Bucur
Enable DM_ETH on all the defconfigs for the P2041RDB board. Signed-off-by: Madalin Bucur <madalin.bucur@oss.nxp.com> Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-05-08configs: Resync with savedefconfigTom Rini
2020-05-04config: P2041RDB: enable DM_I2CBiwen Li
This enables DM_I2C in P2041RDB defconfig, except P2041RDB SRIO_PCIE_BOOT and SECURE_BOOT defconfigs Signed-off-by: Biwen Li <biwen.li@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-04-28Convert CONFIG_PHYLIB et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_PHYLIB CONFIG_BITBANGMII CONFIG_MV88E6352_SWITCH CONFIG_MV88E61XX_SWITCH CONFIG_PHYLIB_10G CONFIG_PHY_AQUANTIA CONFIG_PHY_ATHEROS CONFIG_PHY_BROADCOM CONFIG_PHY_CORTINA CONFIG_PHY_DAVICOM CONFIG_PHY_ET1011C CONFIG_PHY_LXT CONFIG_PHY_MARVELL CONFIG_PHY_MICREL CONFIG_PHY_NATSEMI CONFIG_PHY_REALTEK CONFIG_RTL8211X_PHY_FORCE_MASTER CONFIG_PHY_SMSC CONFIG_PHY_TERANETICS CONFIG_PHY_TI CONFIG_PHY_VITESSE CONFIG_PHY_XILINX Signed-off-by: Tom Rini <trini@konsulko.com>
2019-12-23configs: P2041: enable CONFIG_DM_USB supportRan Wang
Signed-off-by: Ran Wang <ran.wang_1@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-12-03mtd: rename CONFIG_NAND -> CONFIG_MTD_RAW_NANDMiquel Raynal
Add more clarity by changing the Kconfig entry name. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> [trini: Re-run migration, update a few more cases] Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
2019-11-25configs: enable eSDHC device module for P2041RDB boardYinbo Zhu
Enable eSDHC device module for P2041RDB board Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-08-28configs: P2041RDB: Enable PCIe driverHou Zhiqiang
Enable the DM PCIe driver in P2041RDB defconfig. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-08-26powerpc: Enable device tree support for P2041RDBHou Zhiqiang
Add device tree for P1041RDB board and enable CONFIG_OF_CONTROL so that device tree can be compiled. Update board README for device tree usage. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
2019-05-26configs: Migrate CONFIG_FMAN_ENET and some related options to KconfigTom Rini
Move the main symbol for Freescale Fman Ethernet controller option to Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and rename the SPIFLASH one to follow the same format as all of the others. To do this fully we need to migrate CONFIG_QC, do so. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-12Convert CONFIG_NAND to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_NAND Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Sync up a few more, add imply's] Signed-off-by: Tom Rini <trini@konsulko.com>
