path: root/configs/P1025RDB_defconfig
2016-11-23powerpc: P1025RDB: Separate from P1_P2_RDB_PC in KconfigYork Sun
Use TARGET_P1025RDB instead of sharing with P1_P2_RDB_PC to simplify Kconfig and config macros. Remove macro CONFIG_P1025RDB. Signed-off-by: York Sun <york.sun@nxp.com>
