path: root/configs/P1024RDB_NAND_defconfig
2016-11-23powerpc: P1024RDB: Separate from P1_P2_RDB_PC in KconfigYork Sun
Use TARGET_P1024RDB instead of sharing with TARGET_P1_P2_RDB_PC to simplify Kconfig and macros. Remove macro CONFIG_P1024RDB. Signed-off-by: York Sun <york.sun@nxp.com>
2016-09-16Convert CONFIG_SPL_ENV_SUPPORT to KconfigSimon Glass
