path: root/configs/P1020RDB-PD_SPIFLASH_defconfig
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-22Convert CONFIG_CMD_ERRATA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ERRATA Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-11-23powerpc: P1020RDB-PD: Separate from P1_P2_RDB_PC in KconfigYork Sun
Use TARGET_P1020RDB_PD instead of sharing with P1_P2_RDB_PC to simplify Kconfig and config macros. Remove macro CONFIG_P1020RDB_PD. Signed-off-by: York Sun <york.sun@nxp.com>
2016-09-16Convert CONFIG_SPL_ENV_SUPPORT to KconfigSimon Glass
