path: root/configs/P1020RDB-PC_NAND_defconfig
2023-01-10powerpc/mpc85xx: Unset CONFIG_SPL_TARGET="u-boot-with-spl.bin"Pali Rohár
CONFIG_SPL_TARGET should specify additional SPL make target. But u-boot-with-spl.bin is final U-Boot binary, not SPL binary in some custom format. Moreover u-boot-with-spl.bin is already set in CONFIG_BUILD_TARGET, so make will build it by default. Signed-off-by: Pali Rohár <pali@kernel.org>
2022-12-22Convert CONFIG_L2_CACHE to KconfigTom Rini
This converts the following to Kconfig: CONFIG_L2_CACHE Signed-off-by: Tom Rini <trini@konsulko.com>
2022-12-22Convert CONFIG_HOSTNAME et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_GATEWAYIP CONFIG_HOSTNAME CONFIG_IPADDR CONFIG_NETMASK CONFIG_ROOTPATH CONFIG_SERVERIP CONFIG_UBOOTPATH To do this, we introduce a CONFIG_USE_ form of each of the above and change include/env_default.h to test for that to be set before setting a value. Further, we don't want to stringify the IP address related values as they are now properly strings via Kconfig. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-12-05Convert CONFIG_VSC7385_ENET et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_VSC7385_ENET CONFIG_VSC9953 Signed-off-by: Tom Rini <trini@konsulko.com>
2022-12-05Convert CONFIG_RTC_DS1337 et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_RTC_DS1337 CONFIG_RTC_DS1337_NOOSC CONFIG_RTC_DS1338 CONFIG_RTC_DS1374 CONFIG_RTC_DS3231 CONFIG_RTC_MC13XXX CONFIG_RTC_MXS CONFIG_RTC_PT7C4338 Signed-off-by: Tom Rini <trini@konsulko.com>
2022-12-05Convert CONFIG_SYS_NS16550_MEM32 et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SPL_NS16550_MIN_FUNCTIONS CONFIG_SYS_NS16550_MEM32 CONFIG_SYS_NS16550_PORT_MAPPED CONFIG_SYS_NS16550_REG_SIZE CONFIG_SYS_NS16550_SERIAL To do this we also introduce CONFIG_SPL_SYS_NS16550_SERIAL so that platforms can enable the legacy driver here for SPL. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-11-10Convert CONFIG_SYS_MONITOR_LEN to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_MONITOR_LEN To do this, we set a default of 0 for everyone because there are a number of cases where we define CONFIG_SYS_MONITOR_LEN but the only impact is that we set TOTAL_MALLOC_LEN to be CONFIG_SYS_MALLOC_LEN + CONFIG_ENV_SIZE, so we must continue to allow all boards to set this value. Update the SPL code to use 200 KB as the default raw U-Boot size directly, if we don't have a real CONFIG_SYS_MONITOR_LEN value. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2022-11-10Convert CONFIG_SYS_LOADS_BAUD_CHANGE et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_LOADS_BAUD_CHANGE CONFIG_LOADS_ECHO As part of this, we move CMD_SAVES to be after CMD_LOADS as they are logically related (load or save an s-record format file) and this makes grouping of CONFIG_SYS_LOADS_BAUD_CHANGE easier. Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2022-11-10Convert CONFIG_SYS_INIT_RAM_LOCK to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_INIT_RAM_LOCK Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2022-10-31Rename CONFIG_SYS_TEXT_BASE to CONFIG_TEXT_BASESimon Glass
The current name is inconsistent with SPL which uses CONFIG_SPL_TEXT_BASE and this makes it imposible to use CONFIG_VAL(). Rename it to resolve this problem. Signed-off-by: Simon Glass <sjg@chromium.org>
2022-10-21configs: Resync with savedefconfigTom Rini
2022-08-23configs: Resync with savedefconfigTom Rini
2022-08-04Convert CONFIG_SYS_FLASH_QUIET_TEST to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_FLASH_QUIET_TEST Signed-off-by: Tom Rini <trini@konsulko.com>
2022-08-04Convert CONFIG_SYS_MAX_FLASH_SECT to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_MAX_FLASH_SECT Signed-off-by: Tom Rini <trini@konsulko.com>
2022-08-04Convert CONFIG_SYS_FLASH_EMPTY_INFO to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_FLASH_EMPTY_INFO Signed-off-by: Tom Rini <trini@konsulko.com>
2022-07-25configs: Resync with savedefconfigTom Rini
Resync all defconfig files using moveconfig.py Signed-off-by: Tom Rini <trini@konsulko.com>
2022-07-05Convert CONFIG_PCIE1 et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_PCIE1 CONFIG_PCIE2 CONFIG_PCIE3 CONFIG_PCIE4 CONFIG_PCI1 Signed-off-by: Tom Rini <trini@konsulko.com>
2022-07-05Convert CONFIG_SYS_DDR_RAW_TIMING to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_DDR_RAW_TIMING Signed-off-by: Tom Rini <trini@konsulko.com>
2022-07-05Convert CONFIG_SYS_SPD_BUS_NUM to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_SPD_BUS_NUM Signed-off-by: Tom Rini <trini@konsulko.com>
2022-07-05Convert CONFIG_ENABLE_36BIT_PHYS to KconfigTom Rini
This converts the following to Kconfig: CONFIG_ENABLE_36BIT_PHYS Signed-off-by: Tom Rini <trini@konsulko.com>
2022-06-28Convert CONFIG_ENV_RANGE to KconfigTom Rini
This converts the following to Kconfig: CONFIG_ENV_RANGE Now that this is in Kconfig we can enforce a minimum size and so remove the check in C code to ensure range is larger than size. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-06-28Convert CONFIG_USB_MAX_CONTROLLER_COUNT to KconfigTom Rini
This converts the following to Kconfig: CONFIG_USB_MAX_CONTROLLER_COUNT Signed-off-by: Tom Rini <trini@konsulko.com>
2022-06-28Convert CONFIG_SYS_MPC85XX_NO_RESETVEC to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_MPC85XX_NO_RESETVEC Signed-off-by: Tom Rini <trini@konsulko.com>
2022-06-28Convert CONFIG_LBA48 et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_LBA48 CONFIG_SYS_64BIT_LBA Signed-off-by: Tom Rini <trini@konsulko.com>
2022-06-28powerpc: mpc85xx: Set TEXT_BASE addresses to real base valuesPali Rohár
Currently CONFIG_SPL_TEXT_BASE and CONFIG_SYS_TEXT_BASE addresses are manually increased by 0x1000 due to .bootpg section. This section has size of 0x1000 bytes and is manually put by linker script before .text section (and therefore before base address) when CONFIG_SYS_MPC85XX_NO_RESETVEC is set. Due to this fact lot of other config options are manually increased by 0x1000 value to make correct layout. Note that entry point is not on CONFIG_SPL_TEXT_BASE (image+0x1000) but it is really on address CONFIG_SPL_TEXT_BASE-0x1000 (means at the start of the image). Cleanup handling of .bootpg section when CONFIG_SYS_MPC85XX_NO_RESETVEC is set. Put .bootpg code directly into .text section and move text base address to the start of .bootpg code. And finally remove +0x1000 value from lot of config options. With this removal custom PHDRS is not used anymore, so remove it too. After this change entry point would be at CONFIG_SPL_TEXT_BASE and not at address -0x1000 anymore. Tested on P2020 board with SPL and proper U-Boot. Signed-off-by: Pali Rohár <pali@kernel.org>
2022-06-20configs: Resync with savedefconfigTom Rini
2022-06-06Convert CONFIG_SPL_TARGET to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SPL_TARGET Signed-off-by: Tom Rini <trini@konsulko.com>
2022-06-06Convert CONFIG_SPL_GD_ADDR to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SPL_GD_ADDR Signed-off-by: Tom Rini <trini@konsulko.com>
2022-06-06Convert CONFIG_SPL_RELOC_TEXT_BASE et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SPL_RELOC_TEXT_BASE CONFIG_SPL_RELOC_STACK CONFIG_SPL_RELOC_MALLOC_ADDR CONFIG_SPL_RELOC_MALLOC_SIZE Signed-off-by: Tom Rini <trini@konsulko.com>
2022-06-06Convert CONFIG_SPL_COMMON_INIT_DDR to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SPL_COMMON_INIT_DDR Signed-off-by: Tom Rini <trini@konsulko.com>
2022-06-06ppc / layerscape: Clean up CONFIG_SYS_CCSR_DO_NOT_RELOCATE usageTom Rini
A number of PowerPC platforms define this, for SPL. To move this to Kconfig, it needs to be CONFIG_SPL_SYS_CCSR_DO_NOT_RELOCATE, so use CONFIG_IS_ENABLED() to check for usage. A number of layerscape platforms bring this logic from PowerPC, but only need a small part of it, for the fman driver. Remove their unused portion at least. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-06-06Convert CONFIG_SPL_PAD_TO et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SPL_PAD_TO CONFIG_SPL_MAX_SIZE CONFIG_TPL_PAD_TO CONFIG_TPL_MAX_SIZE Note that we need to make TPL_MAX_SIZE be hex, and so move and convert the existing places. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-06-06Convert CONFIG_SPL_INIT_MINIMAL et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SPL_INIT_MINIMAL CONFIG_SPL_FLUSH_IMAGE CONFIG_SPL_SKIP_RELOCATE Signed-off-by: Tom Rini <trini@konsulko.com>
2022-06-06Convert CONFIG_SYS_PBSIZE to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_PBSIZE Signed-off-by: Tom Rini <trini@konsulko.com>
2022-04-26powerpc: mpc85xx: Remove duplicate u-boot-nand.ldsPali Rohár
Signed-off-by: Priyanka Jain <priyanka.jain@nxp.com>
2022-04-20configs: Resync with savedefconfigTom Rini
2022-04-04Merge branch 'next'Tom Rini
2022-04-01Convert CONFIG_SYS_MONITOR_BASE to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_MONITOR_BASE Note that for how this is re-used on some PowePC platforms, we introduce CONFIG_SPL_SYS_MONITOR_BASE and CONFIG_TPL_SYS_MONITOR_BASE and use the CONFIG_VAL macro to get the correct value at build time, in the code. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-03-31powerpc: Fix incorrect SYS_IMMR migration valuesTom Rini
When migrating SYS_IMMR, I didn't allow for boards to provide non-default values here. This lead to an incorrect migration on the platforms where CONFIG_SYS_IMMR is set to CONFIG_SYS_CCSRBAR and CONFIG_SYS_CSSRBAR is NOT the same as CONFIG_SYS_CCSRBAR_DEFAULT. Add text to the prompt so that non-default values can be used and re-migrate the platforms that have CONFIG_SYS_IMMR=CONFIG_SYS_CSSRBAR where CONFIG_SYS_CSSRBAR != CONFIG_SYS_CCSRBAR_DEFAULT. Fixes: be7dbb60c5bf ("Convert CONFIG_SYS_IMMR to Kconfig") Reported-by: Pali Rohár <pali@kernel.org> Signed-off-by: Tom Rini <trini@konsulko.com> Tested-by: Pali Rohár <pali@kernel.org>
2022-03-18Convert CONFIG_ETHPRIME to KconfigTom Rini
This converts the following to Kconfig: CONFIG_ETHPRIME This is also done by adding a gating Kconfig option, CONFIG_USE_ETHPRIME similar to other options that are not always set and control environment variables. Signed-off-by: Tom Rini <trini@konsulko.com>
2022-03-03Convert CONFIG_CHIP_SELECTS_PER_CTRL to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CHIP_SELECTS_PER_CTRL Cc: Alison Wang <alison.wang@nxp.com> Cc: Pramod Kumar <pramod.kumar_1@nxp.com> Cc: Priyanka Jain <priyanka.jain@nxp.com> Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com> Cc: Vladimir Oltean <olteanv@gmail.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2022-03-03Convert CONFIG_BOOTFILE to KconfigTom Rini
This converts the following to Kconfig: CONFIG_BOOTFILE Signed-off-by: Tom Rini <trini@konsulko.com>
2022-01-24configs: Resync with savedefconfigTom Rini
2021-12-27Convert CONFIG_SYS_NAND_U_BOOT_OFFS to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_NAND_U_BOOT_OFFS Signed-off-by: Tom Rini <trini@konsulko.com>
2021-12-27Convert CONFIG_TPL_TEXT_BASE to KconfigTom Rini
This converts the following to Kconfig: CONFIG_TPL_TEXT_BASE Signed-off-by: Tom Rini <trini@konsulko.com>
2021-12-27Convert CONFIG_CONS_INDEX et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_CONS_INDEX CONFIG_DEBUG_UART_CLOCK CONFIG_FSL_TZPC_BP147 CONFIG_GENERIC_ATMEL_MCI CONFIG_IDENT_STRING CONFIG_LIBATA CONFIG_LNX_KRNL_IMG_TEXT_OFFSET_BASE CONFIG_LPC32XX_GPIO CONFIG_MP CONFIG_MPC8XXX_GPIO CONFIG_MTD_PARTITIONS CONFIG_MVGBE CONFIG_MXC_GPIO CONFIG_NR_DRAM_BANKS CONFIG_OF_BOARD_SETUP CONFIG_OF_STDOUT_VIA_ALIAS CONFIG_OF_SYSTEM_SETUP CONFIG_PREBOOT CONFIG_ROCKCHIP_SERIAL CONFIG_RTC_ENABLE_32KHZ_OUTPUT CONFIG_RTC_MV CONFIG_SCSI_AHCI CONFIG_SF_DEFAULT_BUS CONFIG_SF_DEFAULT_CS CONFIG_SF_DEFAULT_SPEED CONFIG_SOFT_SPI CONFIG_SPI_FLASH_EON CONFIG_SPI_FLASH_MACRONIX CONFIG_SPI_FLASH_MTD CONFIG_SPI_FLASH_SPANSION CONFIG_SPI_FLASH_SST CONFIG_SPI_FLASH_STMICRO CONFIG_SUPPORT_RAW_INITRD CONFIG_SYS_ARCH_TIMER CONFIG_SYS_BOARD CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE CONFIG_SYS_DCACHE_OFF CONFIG_SYS_FDT_SAVE_ADDRESS CONFIG_SYS_FLASH_CFI CONFIG_SYS_FSL_ERRATUM_ESDHC135 CONFIG_SYS_HAS_SERDES CONFIG_SYS_L2CACHE_OFF CONFIG_SYS_LITTLE_ENDIAN CONFIG_SYS_LOAD_ADDR CONFIG_SYS_MMCSD_FS_BOOT_PARTITION CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_USE_SECTOR CONFIG_SYS_NS16550 CONFIG_SYS_PLLFIN CONFIG_SYS_SPI_U_BOOT_OFFS CONFIG_TIMER_SYS_TICK_CH CONFIG_USB_EHCI_FSL CONFIG_U_QE CONFIG_VERSION_VARIABLE Signed-off-by: Tom Rini <trini@konsulko.com>
2021-12-01Convert CONFIG_SYS_BR0_PRELIM et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_SYS_BR0_PRELIM CONFIG_SYS_OR1_PRELIM CONFIG_SYS_BR1_PRELIM CONFIG_SYS_OR2_PRELIM CONFIG_SYS_BR2_PRELIM CONFIG_SYS_OR2_PRELIM CONFIG_SYS_BR3_PRELIM CONFIG_SYS_OR3_PRELIM CONFIG_SYS_BR4_PRELIM CONFIG_SYS_OR4_PRELIM CONFIG_SYS_BR5_PRELIM CONFIG_SYS_OR5_PRELIM CONFIG_SYS_BR6_PRELIM CONFIG_SYS_OR6_PRELIM CONFIG_SYS_BR7_PRELIM CONFIG_SYS_OR7_PRELIM This also introduces CONFIG_SYS_BR0_PRELIM_BOOL as not all platforms that can set these values do so. Add the relevant SYS_BRx_PRELIM_BOOL to platforms that had not been previously migrated. Signed-off-by: Tom Rini <trini@konsulko.com>
2021-12-01Convert CONFIG_USE_BOOTCOMMAND et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_USE_BOOTCOMMAND CONFIG_BOOTCOMMAND CONFIG_RAMBOOTCOMMAND CONFIG_NFSBOOTCOMMAND Signed-off-by: Tom Rini <trini@konsulko.com>
2021-11-01configs: Resync with savedefconfigTom Rini
2021-10-15configs: Resync with savedefconfigTom Rini
