path: root/configs/P1020RDB-PC_NAND_defconfig
2017-05-22Convert CONFIG_CMD_ERRATA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ERRATA Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-11-23powerpc: P1020RDB-PC: Separate from P1_P2_RDB_PC in KconfigYork Sun
Use TARGET_P1020RDB_PC instead of sharing with TARGET_P1_P2_RDB_PC to simplify Kconfig and config macros. Remove macro CONFIG_P1020RDB_PC. Signed-off-by: York Sun <york.sun@nxp.com>
2016-09-16Convert CONFIG_SPL_ENV_SUPPORT to KconfigSimon Glass
