The following boards no longer need CONFIG_DM_PCI_COMPAT enabled, so
remove that.
commit 0cfccb54014b ("configs: Resync with savedefconfig")
removed CONFIG_USB_STORAGE from some powerpc platforms' defconfig
files, whicih would block the use case of system loading rootfs
from USB drives, add them back.
Signed-off-by: Ran Wang <ran.wang_1@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
Enable the DM_ETH and DM_MDIO config.
On P1020RDB, the eTSEC1 is connecting with a switch VSC7385,
so also enable the fixed PHY support.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
Enable the DM ESPI driver in P1020RDB defconfig.
Signed-off-by: Xiaowei Bao <xiaowei.bao@nxp.com>
CONFIG_ENV_OVERWRITE
[trini: Rerun migration, remove some comments]
Move ADDR_MAP related config options from include/configs/*.h to the
proper place in lib/Kconfig. This has been done using
./tools/moveconfig.py and manual inspection of the generated changes.
This is a preparation to use ADDR_MAP helper on ARM 32bit Raspberry Pi4
board for mapping the PCIe XHCI MMIO, which is above the 4GiB identity
mapping limit.
This enables DM_I2C and DM_RTC in P1020RDB defconfigs
Signed-off-by: Biwen Li <biwen.li@nxp.com>
CONFIG_PHYLIB
CONFIG_BITBANGMII
CONFIG_MV88E6352_SWITCH
CONFIG_MV88E61XX_SWITCH
CONFIG_PHYLIB_10G
CONFIG_PHY_AQUANTIA
CONFIG_PHY_ATHEROS
CONFIG_PHY_BROADCOM
CONFIG_PHY_CORTINA
CONFIG_PHY_DAVICOM
CONFIG_PHY_ET1011C
CONFIG_PHY_LXT
CONFIG_PHY_MARVELL
CONFIG_PHY_MICREL
CONFIG_PHY_NATSEMI
CONFIG_PHY_REALTEK
CONFIG_RTL8211X_PHY_FORCE_MASTER
CONFIG_PHY_SMSC
CONFIG_PHY_TERANETICS
CONFIG_PHY_TI
CONFIG_PHY_VITESSE
CONFIG_PHY_XILINX
Both symbols must be enabled when there is a raw NAND driver
selected. Also enable them when CONFIG_CMD_NAND is selected to avoid
breaking things when we'll further rework the MTD dependency
description.
Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com>
[trini: Rebase and migrate a few more boards here]
Enable eSDHC device module for P1020RDB board
Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Enable the DM PCIe driver in P1020RDB defconfig.
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Add device tree for P1020RDB boards and enable CONFIG_OF_CONTROL
so that device tree can be compiled.
Update board README for device tree usage.
CONFIG_SF_DEFAULT_BUS
CONFIG_SF_DEFAULT_CS
CONFIG_SF_DEFAULT_MODE
CONFIG_SF_DEFAULT_SPEED
I use moveconfig script and then manual check on generated u-boot.cfg
to solve the remaining issue.
CONFIG_FLASH_CFI_DRIVER
CONFIG_SYS_FLASH_USE_BUFFER_WRITE
CONFIG_FLASH_CFI_MTD
CONFIG_SYS_FLASH_PROTECTION
CONFIG_SYS_FLASH_CFI
[trini: Re-migrate]
CONFIG_MISC_INIT_R
[trini: Update the defaults logic slightly]
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
This patch moves CONFIG_MP to Kconfig
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
The CONFIG_PHY_MARVELL has already been migrated to Kconfig (some boards
already had it in their Kconfig), but had not been moved for older
boards.
Move it to the defconfigs for all boards.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
CONFIG_SPI
This partly involves updating code that assumes that CONFIG_SPI implies
things that are specific to the MPC8xx SPI driver. For now, just update
the CONFIG tests. This also involves reworking the default for
CONFIG_SYS_DEF_EEPROM_ADDR so that we don't set it when we cannot make a
reasonable default, as it does not cause any compile failures.
Migrate the CONFIG_FSL_ESDHC option to Kconfig.
Migrate the CONFIG_TSEC_ENET option to Kconfig.
Migrate the CONFIG_BOARD_EARLY_INIT_R option to Kconfig.
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
Signed-off-by: Alexandru Gagniuc <alex.g@adaptrum.com>
CONFIG_ENV_IS_IN_FLASH
CONFIG_CMD_HASH
[trini: Rework slightly, enable on some boards again]
CONFIG_CMD_ERRATA
Signed-off-by: Chris Packham <judge.packham@gmail.com>
[trini: default y if DM_RTC, re-sync]
We repeated partial moves for CONFIG_SYS_NO_FLASH, but this is
not completed. Finish this work by the tool.
During this move, let's rename it to CONFIG_MTD_NOR_FLASH.
Actually, we have more instances of "#ifndef CONFIG_SYS_NO_FLASH"
than those of "#ifdef CONFIG_SYS_NO_FLASH". Flipping the logic will
make the code more readable. Besides, negative meaning symbols do
not fit in obj-$(CONFIG_...) style Makefiles.
This commit was created as follows:
[1] Edit "default n" to "default y" in the config entry in
common/Kconfig.
[2] Run "tools/moveconfig.py -y -r HEAD SYS_NO_FLASH"
[3] Rename the instances in defconfigs by the following:
find . -path './configs/*_defconfig' | xargs sed -i \
-e '/CONFIG_SYS_NO_FLASH=y/d' \
-e 's/# CONFIG_SYS_NO_FLASH is not set/CONFIG_MTD_NOR_FLASH=y/'
[4] Change the conditionals by the following:
find . -name '*.[ch]' | xargs sed -i \
-e 's/ifndef CONFIG_SYS_NO_FLASH/ifdef CONFIG_MTD_NOR_FLASH/' \
-e 's/ifdef CONFIG_SYS_NO_FLASH/ifndef CONFIG_MTD_NOR_FLASH/' \
-e 's/!defined(CONFIG_SYS_NO_FLASH)/defined(CONFIG_MTD_NOR_FLASH)/' \
-e 's/defined(CONFIG_SYS_NO_FLASH)/!defined(CONFIG_MTD_NOR_FLASH)/'
[5] Modify the following manually
- Rename the rest of instances
- Remove the description from README
- Create the new Kconfig entry in drivers/mtd/Kconfig
- Remove the old Kconfig entry from common/Kconfig
- Remove the garbage comments from include/configs/*.h
CONFIG_BOARD_EARLY_INIT_F
Use TARGET_P1020RDB_PC instead of sharing with TARGET_P1_P2_RDB_PC
to simplify Kconfig and config macros.
Remove macro CONFIG_P1020RDB_PC.
Signed-off-by: York Sun <york.sun@nxp.com>
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
We need to ensure that CONFIG_PHYS_64BIT is configured via Kconfig so
that it is always available to the build system. Otherwise we can run
into cases where we have inconsistent sizes of certain attributes.
Ravi Babu reported offset mismatch of struct dwc3 across files since
commit 95ebc253e6d4 ("types.h: move and redefine resource_size_t").
Since the commit, resource_addr_t points to phys_addr_t, whose size
is dependent on CONFIG_PHYS_64BIT for ARM architecture.
I tried my best to use "select" where possible (for example, ARMv8
architecture) because I think this kind of option is generally user-
unconfigurable. However, I see some of PowerPC boards have 36BIT
defconfigs as well as 32BIT ones. I moved CONFIG_PHYS_64BIT to the
defconfigs for such boards.
CONFIG_36BIT is no longer referenced, so all of the defines were
removed from CONFIG_SYS_EXTRA_OPTIONS.
Fixes: 95ebc253e6d4 ("types.h: move and redefine resource_size_t")
Reported-by: Ravi Babu <ravibabu@ti.com>
Reviewed-by: York Sun <york.sun@nxp.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
