path: root/configs/P1020MBG-PC_SDCARD_defconfig
2018-04-08treewide: Migrate CONFIG_TSEC_ENET to KconfigMario Six
Migrate the CONFIG_TSEC_ENET option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2017-05-22Convert CONFIG_CMD_ERRATA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ERRATA Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-11-23powerpc: P1020MBG: Separate from P1_P2_RDB_PC in KconfigYork Sun
Use TARGET_P1020MBG instead of sharing with TARGET_P1_P2_RDB_PC to simplify Kconfig and other macros. Remove macro CONFIG_P1020MBG. Signed-off-by: York Sun <york.sun@nxp.com>
2016-09-16Convert CONFIG_SPL_ENV_SUPPORT to KconfigSimon Glass
