Move this option to Kconfig and tidy up existing uses.
Move the SPL settings into common/spl where most of the SPL code is kept.
In some cases we were missing CONFIG_USB=y so enable that when needed.
Reviewed-by: Masahiro Yamada <yamada.masahiro@socionext.com>
We need to ensure that CONFIG_PHYS_64BIT is configured via Kconfig so
that it is always available to the build system. Otherwise we can run
into cases where we have inconsistent sizes of certain attributes.
Ravi Babu reported offset mismatch of struct dwc3 across files since
commit 95ebc253e6d4 ("types.h: move and redefine resource_size_t").
Since the commit, resource_addr_t points to phys_addr_t, whose size
is dependent on CONFIG_PHYS_64BIT for ARM architecture.
I tried my best to use "select" where possible (for example, ARMv8
architecture) because I think this kind of option is generally user-
unconfigurable. However, I see some of PowerPC boards have 36BIT
defconfigs as well as 32BIT ones. I moved CONFIG_PHYS_64BIT to the
defconfigs for such boards.
CONFIG_36BIT is no longer referenced, so all of the defines were
removed from CONFIG_SYS_EXTRA_OPTIONS.
Fixes: 95ebc253e6d4 ("types.h: move and redefine resource_size_t")
Reported-by: Ravi Babu <ravibabu@ti.com>
Reviewed-by: York Sun <york.sun@nxp.com>
move CONFIG_BOOTDELAY into a Kconfig option. Used for this
purpose the moveconfig.py tool in tools.
Acked-by: Viresh Kumar <viresh.kumar@linaro.org>
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
There are already two FIT options in Kconfig but the CONFIG options are
still in the header files. We need to do a proper move to fix this.
Move these options to Kconfig and tidy up board configuration:
CONFIG_FIT
CONFIG_OF_BOARD_SETUP
CONFIG_OF_SYSTEM_SETUP
CONFIG_FIT_SIGNATURE
CONFIG_FIT_BEST_MATCH
CONFIG_FIT_VERBOSE
CONFIG_OF_STDOUT_VIA_ALIAS
CONFIG_RSA
Unfortunately the first one is a little complicated. We need to make sure
this option is not enabled in SPL by this change. Also this option is
enabled automatically in the host builds by defining CONFIG_FIT in the
image.h file. To solve this, add a new IMAGE_USE_FIT #define which can
be used in files that are built on the host but must also build for U-Boot
and SPL.
Note: Masahiro's moveconfig.py script is amazing.
[trini: Add microblaze change, various configs/ re-applies]
There are already Kconfig options for SPI drivers, but we
have not moved them from config.h to defconfig files. This
commit does this in a batch.
Move config for the E1000 Ethernet driver to Kconfig and tidy up affected
boards.
them from include/configs.
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
Another shell scripting command that has not been moved.
Moved using tools/moveconfig.py using these settings:
CMD_SETEXPR bool n y
In order to reduce merge conflicts and to maintain the simplest possible
defconfig files, we should be using the savedefconfig feature of Kconfig
every time a new feature is added. This keeps the defconfig settings to
a minimum (only those things not default) and keeps them in the same
order as the Kconfig options.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Since commit e02ee2548afe (kconfig: switch to single .config
configuration), the prefixes in defconfig files such as "+S:",
"+ST:", etc., are meaningless.
This commit was generated by the following command:
find configs -name '*_defconfig' | xargs sed -i 's/^+*S*T*://'
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
