path: root/configs/P1010RDB-PA_SPIFLASH_SECBOOT_defconfig
2016-09-16Move existing use of CONFIG_SPL_RSA to KconfigSimon Glass
A few boards define this in a header file which is incorrect. It means that Kconfig options that rely on this cannot be used. Move it. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-14freescale: Remove CONFIG_DM from header filesSimon Glass
Kconfig options must defined in the defconfig files. Since RSA_SOFTWARE_EXP relies on CONFIG_DM, unless it is set in kconfig we cannot enable RSA. Remove the hacks which enable CONFIG_DM in header files and update the defconfig. Signed-off-by: Simon Glass <sjg@chromium.org>
