path: root/configs/P1010RDB-PA_NOR_defconfig
2018-04-08treewide: Migrate CONFIG_TSEC_ENET to KconfigMario Six
Migrate the CONFIG_TSEC_ENET option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2016-11-23powerpc: P1010RDB: Remove macros CONFIG_P1010RDB_PA and CONFIG_P1010RDB_PBYork Sun
Remove CONFIG_P1010RDB_PA and CONFIG_P1010RDB_PB and split TARGET_P1010RDB to TARGET_P1010RDB_PA and TARGET_P1010RDB_PB in Kconfig. Signed-off-by: York Sun <york.sun@nxp.com>
