path: root/configs/P1010RDB-PA_36BIT_SDCARD_defconfig
2020-05-08configs: Resync with savedefconfigTom Rini
2020-05-04configs: P1010RDB: Enable PCIe driverHou Zhiqiang
Enable the DM PCIe driver in P1010RDB defconfigs. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-05-04powerpc: Enable device tree support for P1010RDBHou Zhiqiang
Add device tree for P1010RDB boards and enable CONFIG_OF_CONTROL so that device tree can be compiled. Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-05-04configs: P1010: Enable DM_I2C and DM_RTCBiwen Li
Enable DM_I2C and DM_RTC in P1010RDB defconfigs, except P1010RDB SECBOOT defconfigs. Signed-off-by: Biwen Li <biwen.li@nxp.com> Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
2020-04-28Merge branch 'migrate-various-PHY-options'Tom Rini
- Finish migration of CONFIG_PHYLIB and a number of related symbols to defconfig files.
2020-04-28configs: Resync with savedefconfigTom Rini
2020-04-28Convert CONFIG_PHYLIB et al to KconfigTom Rini
This converts the following to Kconfig: CONFIG_PHYLIB CONFIG_BITBANGMII CONFIG_MV88E6352_SWITCH CONFIG_MV88E61XX_SWITCH CONFIG_PHYLIB_10G CONFIG_PHY_AQUANTIA CONFIG_PHY_ATHEROS CONFIG_PHY_BROADCOM CONFIG_PHY_CORTINA CONFIG_PHY_DAVICOM CONFIG_PHY_ET1011C CONFIG_PHY_LXT CONFIG_PHY_MARVELL CONFIG_PHY_MICREL CONFIG_PHY_NATSEMI CONFIG_PHY_REALTEK CONFIG_RTL8211X_PHY_FORCE_MASTER CONFIG_PHY_SMSC CONFIG_PHY_TERANETICS CONFIG_PHY_TI CONFIG_PHY_VITESSE CONFIG_PHY_XILINX Signed-off-by: Tom Rini <trini@konsulko.com>
2020-01-22configs: Resync with savedefconfigTom Rini
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-09-23configs: Resync with savedefconfigTom Rini
2019-06-14configs: Migrate the various SPL_BOOT_xxx choices for PowerPCTom Rini
The non-CONFIG_SPL_FRAMEWORK SPL used on some PowerPC platforms have a choice between CONFIG_SPL_NAND_BOOT, CONFIG_SPL_MMC_BOOT and CONFIG_SPL_SPI_BOOT. Migrate this to Kconfig Signed-off-by: Tom Rini <trini@konsulko.com>
2018-04-08treewide: Migrate CONFIG_TSEC_ENET to KconfigMario Six
Migrate the CONFIG_TSEC_ENET option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2016-11-23powerpc: P1010RDB: Remove macros CONFIG_P1010RDB_PA and CONFIG_P1010RDB_PBYork Sun
Remove CONFIG_P1010RDB_PA and CONFIG_P1010RDB_PB and split TARGET_P1010RDB to TARGET_P1010RDB_PA and TARGET_P1010RDB_PB in Kconfig. Signed-off-by: York Sun <york.sun@nxp.com>
2016-09-16Convert CONFIG_SPL_ENV_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_DRIVERS_MISC_SUPPORT to KconfigSimon Glass
