path: root/configs/Orangepi_mini_defconfig
2017-07-11Convert CONFIG_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SCSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-04-20sunxi: Convert CONFIG_MACPWR to KconfigMylène Josserand
Convert the CONFIG_MACPWR to Kconfig and update all the sunxi defconfigs that used it in SYS_EXTRA_OPTIONS. Signed-off-by: Mylène Josserand <mylene.josserand@free-electrons.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Convert CONFIG_RGMII to KconfigMylène Josserand
Convert CONFIG_RGMII to Kconfig. Thanks to that, it is possible to update defconfig files of SYS_EXTRA_OPTIONS accordingly and remove it when it is possible. Signed-off-by: Mylène Josserand <mylene.josserand@free-electrons.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Move SUNXI_GMAC to KconfigMylène Josserand
Move the SUNXI_GMAC config option to Kconfig, remove it from SYS_EXTRA_OPTIONS and rename it into SUN7I_GMAC. Signed-off-by: Mylène Josserand <mylene.josserand@free-electrons.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-11-28sunxi: Use the available Kconfig option for AHCIJelle van der Waa
Use the already available Kconfig option for AHCI. Tested on the BananaPi. Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-05-25sunxi: Enable a bunch of commands by default on sunxiHans de Goede
Recently a set of CONFIG_CMD_FOO defines was moved from being defined in config_distro_defaults to Kconfig, and added to all sunxi defconfigs to compensate. Instead of explictly selecting these in all sunxi defconfigs, simply always select these for sunxi boards. This makes the defconfigs simpler and ensures a consistent set of available commands across all sunxi boards. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-04-12sunxi: Enable CMD_GPIO on all sunxi boardsHans de Goede
We have CONFIG_CMD_GPIO=y in almost all sunxi boards, but after its Kconfig conversion it has ended up missing on some recently added boards. Simply select it for ARCH_SUNXI, so that we get it on all sunxi boards for both a consistent user experience and simpler defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-03-23sunxi: Select CONFIG_OF_BOARD_SETUP from arch/arm/KconfigHans de Goede
Always select OF_BOARD_SETUP on sunxi, rather then having it in almost all our defconfigs. This also fixes it missing from some recently added defconfigs. This commit also modifies our ft_board_setup() to not cause warnings when CONFIG_VIDEO_DT_SIMPLEFB is not set, since we will now always build it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-12-10sunxi: select SYS_NS16550 from KconfigHans de Goede
Select SYS_NS16550 from Kconfig instead of setting it in all our defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-10-20sunxi: Kconfig-ify CONFIG_AXP152_POWER and _AXP209_POWERHans de Goede
Kconfig-ify CONFIG_AXP152_POWER and _AXP209_POWER settings, removing them from CONFIG_SYS_EXTRA_OPTIONS. Note that sun5i boards can have either an AXP209 or an AXP152 pmic, the Kconfig default is AXP209, boards with an AXP152 must explicitly select this. Likewise boards without a pmic must explicitly select SUNXI_NO_PMIC in their defconfig. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-08-14sunxi: display: Enable composite video support on more boardsHans de Goede
Enable composite video support on all boards which have a composite video out connector (either cinch or jack). Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-04sunxi: Move all boards to the driver-modelHans de Goede
Now that we've everything prepared for it remove the DM settings from the defconfig(s) and simply always set them for sunxi. This makes all sunxi boards allways use the driver model for gpios and ethernet, and allows us to move over more bits to the driver-model without the need to introduce #ifdef-ery for boards which are not yet using DM. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-04-18Kconfig: Move CONFIG_DESIGNWARE_ETH to KconfigSimon Glass
Move this to Kconfig and clean up board config files that use it. Also rename it to CONFIG_ETH_DESIGNWARE to fit with the naming that exists in drivers/net/Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org> Version 1: Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-04-04sunxi: Fix Orangepi_mini dtb filenameHans de Goede
The Orangepi_mini is different enough from the regular Orangepi that it needs its own dtb, but when it got added a copy and paste error was made and it got the same dtb filename, fix this. While at it also add a short description of both Orangepi boards to the defconfig files for them. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-03-10sun7i: Add support for the Orange Pi Mini boardHans de Goede
The Orange Pi Mini is an A20 based development board featuring 1G RAM, HDMI, 1Gbit ethernet, USB wifi, SATA, 2 sdcard slots (use the top one for booting), 2 USB 2.0 A receptacles, a micro USB B receptacle (otg) and a 3 ring 3.5 mm jack connector for A/V. Also see: http://www.orangepi.org/ Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
