path: root/configs/O2MNT_O2M112_defconfig
2017-05-15i2c: Drop use of CONFIG_I2C_HARDSimon Glass
This option is pretty old. It predates CONFIG_SYS_I2C which is itself deprecated in favour of driver model. Disable it for all boards. Also drop I2C options which depend on this. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-01-28disk: convert CONFIG_MAC_PARTITION to KconfigPatrick Delaunay
