path: root/configs/MSI_Primo81_defconfig
2020-03-18sunxi: Remove no longer needed default options from defconfigsAndre Przywara
Now that those common Allwinner config symbols are defined automatically for all boards in their Kconfig files, we can remove the now redundant definitions from the boards' _defconfig files. Some boards had a differing definiton for some of those symbols, it looks like mostly to "merge races" when the symbol was introduced (new board *_defconfig file missed the "add symbol to all files" patch). Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <mripard@kernel.org> Tested-by: Jagan Teki <jagan@amarulasolutions.com> # Amarula A64-Relic Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2019-12-04configs: Resync with savedefconfigTom Rini
2019-08-02Convert CONFIG_USE_PREBOOT and CONFIG_PREBOOT to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USE_PREBOOT CONFIG_PREBOOT Both are together in one commit, since otherwise the former causes kconfig to define the latter, which gives duplicate symbol errors. Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the backslash lands in the wrong place. Similarly with socfpga_vining_fpga. Signed-off-by: Simon Glass <sjg@chromium.org>
2019-07-15sunxi: move CONFIG_SPL_TEXT_BASE from *_defconfig to KconfigAndre Przywara
The choice of the SPL_TEXT_BASE is not really a decision that should be specified by each board's defconfig, as this setting is actually dictated by the SoC's memory map and the BootROM behaviour. To make this obvious and reduce the clutter in the defconfig files, let's specify the SoC constraints in the Kconfig stanza. This allows us to remove these lines from the defconfig files again. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
2018-04-16part: Disable CONFIG_SPL_ISO_PARTITION by defaultAlexander Graf
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot could load distro images that usually get shipped as iso images. These images usually come with a board agnostic boot environment. However, there is very little point in having ISO support enabled (for anyone really) in SPL, as the whole idea of SPL is to load U-Boot proper which again is board specific. So the fact that we enable ISO support in U-Boot proper does not mean at all that we want ISO support in U-Boot SPL. Hence, let's remove the Kconfig dependency. Along the way, let's also clean up all those default configs that disabled SPL ISO support. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-03-14sunxi: move CONFIG_SYS_TEXT_BASE out of defconfigsAndre Przywara
Commit 278b90ce786f ("configs: Migrate CONFIG_SYS_TEXT_BASE") made CONFIG_SYS_TEXT_BASE a proper Kconfig variable, with the consequence of moving the common definition shared by almost every sunxi board into 123 individual defconfig files. But the U-Boot start address for Allwinner boards is a platform decision which has been around for ages, so defining it in each *board* config file seems a bit over the top. Define the standard values (160MB into DRAM for most SoCs, with two SoC exceptions) if ARCH_SUNXI is selected, and delete the lines from the individual defconfigs. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VGA_AS_SINGLE_DEVICE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VGA_AS_SINGLE_DEVICE Once we migrate to driver model for video, we should be able to drop this option. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-08-26sunxi: Sync dts files with upstream kernelHans de Goede
Sync dts files with the current (Aug 18th 2016) state of Maxime's linux/sunxi/for-next repo. Note this commit also updates configs/MSI_Primo81_defconfig, adding: "# CONFIG_REQUIRE_SERIAL_CONSOLE is not set", this is necessary because the tablet does not have a reachable uart so the dts sync drops its serial0 alias. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-05-25sunxi: Enable a bunch of commands by default on sunxiHans de Goede
Recently a set of CONFIG_CMD_FOO defines was moved from being defined in config_distro_defaults to Kconfig, and added to all sunxi defconfigs to compensate. Instead of explictly selecting these in all sunxi defconfigs, simply always select these for sunxi boards. This makes the defconfigs simpler and ensures a consistent set of available commands across all sunxi boards. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-04-12sunxi: Enable CMD_GPIO on all sunxi boardsHans de Goede
We have CONFIG_CMD_GPIO=y in almost all sunxi boards, but after its Kconfig conversion it has ended up missing on some recently added boards. Simply select it for ARCH_SUNXI, so that we get it on all sunxi boards for both a consistent user experience and simpler defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-03-23sunxi: Select CONFIG_OF_BOARD_SETUP from arch/arm/KconfigHans de Goede
Always select OF_BOARD_SETUP on sunxi, rather then having it in almost all our defconfigs. This also fixes it missing from some recently added defconfigs. This commit also modifies our ft_board_setup() to not cause warnings when CONFIG_VIDEO_DT_SIMPLEFB is not set, since we will now always build it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-12-10sunxi: select SYS_NS16550 from KconfigHans de Goede
Select SYS_NS16550 from Kconfig instead of setting it in all our defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-10-20sunxi: power: Make all voltages configurable through KconfigHans de Goede
On boards with axp221/223 pmic-s we already allow configuring most voltages. Make the Kconfig options for these also apply to boards with axp152 / axp209 pmic-s and extend them to configure all voltages. The Kconfig defaults are chosen so that this commit does not introduce any functional changes. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-08-21Tidy up some defconfig filesSimon Glass
Several files are out of order. This means that when the moveconfig tool moves CONFIG options to Kconfig it generates a large diff. To avoid this, reorder the files first. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05sunxi: usb: USB_MUSB_SUNXI move to musb-new KconfigPaul Kocialkowski
Now that the musb-new driver has a Kconfig, we can move Kconfig options to enable controllers to it, so that it's easier in e.g. menuconfig. In addition, this allows declaring support for USB_MUSB_HOST/GADGET in defconfigs instead of the USB_MUSB_SUNXI controller, that will get selected automatically when needed. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-06-17MSI_Primo81_defconfig: enable USB OTG port and keyboard supportKarsten Merker
The MSI Primo 81 is an Allwinner A31s-based tablet on which the OTG port is the only accessible USB interface. The existing defconfig had VGA console on the LCD enabled, but was missing keyboard support because the prerequisites for that (sunxi MUSB support and AXP221 GPIO support) had not been available before. All previously missing dependencies are available now, so this patch enables keyboard support and its prerequisites in the defconfig. Signed-off-by: Karsten Merker <merker@debian.org> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-22sun6i: Add LCD display support for MSI Primo81 tabletSiarhei Siamashka
The MSI Primo81 tablet has B079XAN01/LP079X01 7.85" 768x1024 IPS MIPI display, connected to the parallel LCD interface via SSD2828 bridge chip. The panel has 18-bit color depth and needs dithering, in spite of having RGB data delivered from A31s to SSD2828 using 24-bit arrangement. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Anatolij Gustschin <agust@denx.de> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-22sunxi: Remove CONFIG_TARGET_FOO for sun4i, sun6i and sun8i boardsHans de Goede
CONFIG_TARGET_FOO is only used in board/sunxi/Makefile to select the dram config for sun5i and sun7i boards and in board/sunxi/gmac.c for some special handling of the bananapi/bananapro (both sun7i), iow it is not used at all on any sun4i, sun6i and sun8i boards so lets get rid of it there. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sun6i: Add defconfig for MSI Primo81 tabletSiarhei Siamashka
This patch uses the same ZQ and DRAM clock settings as in the pre-installed Android firmware. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
