path: root/configs/MPC8572DS_defconfig
2017-10-30configs: Resync with savedefconfigTom Rini
2017-08-21usb: ehci: Convert CONFIG_USB_EHCI_PCI to KconfigBin Meng
This converts CONFIG_USB_EHCI_PCI to a Kconfig option, and updates all boards that use it. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2017-08-11Convert CONFIG_CMD_REGINFO to KconfigChristophe Leroy
This patch converts CONFIG_CMD_REGINFO to Kconfig Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-01-04fsl_ddr: Move DDR config options to driver KconfigYork Sun
Create driver/ddr/fsl/Kconfig and move existing options. Clean up existing macros. Signed-off-by: York Sun <york.sun@nxp.com> [trini: Migrate sbc8641d, xpedite537x and MPC8536DS, run a moveconfig.py -s] Signed-off-by: Tom Rini <trini@konsulko.com>
