path: root/configs/MPC8541CDS_defconfig
2017-08-11Convert CONFIG_CMD_REGINFO to KconfigChristophe Leroy
This patch converts CONFIG_CMD_REGINFO to Kconfig Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr> Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-05-22Convert CONFIG_CMD_ERRATA to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_ERRATA Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
