path: root/configs/MPC832XEMDS_defconfig
2020-07-28Convert CONFIG_ENV_OVERWRITE to KconfigAdam Ford
This converts the following to Kconfig: CONFIG_ENV_OVERWRITE Signed-off-by: Adam Ford <aford173@gmail.com> [trini: Rerun migration, remove some comments] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-26configs: Resync with savedefconfigTom Rini
2019-05-26configs: Migrate CONFIG_FMAN_ENET and some related options to KconfigTom Rini
Move the main symbol for Freescale Fman Ethernet controller option to Kconfig. Also migrate the CONFIG_SYS_QE_FMAN_FW_IN_xxx macros and rename the SPIFLASH one to follow the same format as all of the others. To do this fully we need to migrate CONFIG_QC, do so. Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-21mpc83xx: Migrate CONFIG_LCRR_* to KconfigMario Six
Migrate the CONFIG_LCRR_* settings to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate HID config to KconfigMario Six
Mirate the HID configuration settings to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate CONFIG_SYS_{BR, OR}*_PRELIM to KconfigMario Six
Migrate the BR/OR settings to Kconfig. These must be known at compile time, so cannot be configured via DT. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate LBLAW_* to KconfigMario Six
The LBLAW_* values determine the window configuration of the memory controller. Hence, they must be known at compile time, and cannot be implemented in the DT mechanism. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate BATS config to KconfigMario Six
The BATs (block address translation registers) determine the initial memory window mappings. Hence, they must be known at compile time and cannot be implemented in the DT mechanism. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21powerpc: Migrate HIGH_BATS to KconfigMario Six
Migrate the CONFIG_HIGH_BATS variable to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Kconfig: Migrate HRCW to KconfigMario Six
The HRCW (hardware reset configuration word) is a constant that must be hard-coded into the boot loader image. So, it must be available at compile time, and cannot be migrated to the DT mechanism, but has to be kept in Kconfig. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Get rid of CONFIG_83XX_CLKINMario Six
MPC83xx uses CONFIG_83XX_CLKIN instead of CONFIG_SYS_CLK_FREQ to set the system clock. To migrate the architecture, we can replace CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ. To do this * replace all occurrences of CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ * set CONFIG_SYS_CLK_FREQ to the old value of CONFIG_83XX_CLKIN in all MPC83xx config files Signed-off-by: Mario Six <mario.six@gdsys.cc>
