path: root/configs/MPC8313ERDB_33_defconfig
2019-12-04configs: Resync with savedefconfigTom Rini
2019-12-04mtd: ensure MTD/the raw NAND core are compiled when there is a NAND flashMiquel Raynal
Both symbols must be enabled when there is a raw NAND driver selected. Also enable them when CONFIG_CMD_NAND is selected to avoid breaking things when we'll further rework the MTD dependency description. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com> Reviewed-by: Boris Brezillon <boris.brezillon@bootlin.com> [trini: Rebase and migrate a few more boards here] Signed-off-by: Tom Rini <trini@konsulko.com>
2019-05-26configs: Resync with savedefconfigTom Rini
2019-05-21mpc83xx: Migrate CONFIG_LCRR_* to KconfigMario Six
Migrate the CONFIG_LCRR_* settings to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate arbiter config to KconfigMario Six
Migrate the arbiter configuration to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate HID config to KconfigMario Six
Mirate the HID configuration settings to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate CONFIG_SYS_{BR, OR}*_PRELIM to KconfigMario Six
Migrate the BR/OR settings to Kconfig. These must be known at compile time, so cannot be configured via DT. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate LBLAW_* to KconfigMario Six
The LBLAW_* values determine the window configuration of the memory controller. Hence, they must be known at compile time, and cannot be implemented in the DT mechanism. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Migrate BATS config to KconfigMario Six
The BATs (block address translation registers) determine the initial memory window mappings. Hence, they must be known at compile time and cannot be implemented in the DT mechanism. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21powerpc: Migrate HIGH_BATS to KconfigMario Six
Migrate the CONFIG_HIGH_BATS variable to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Kconfig: Migrate HRCW to KconfigMario Six
The HRCW (hardware reset configuration word) is a constant that must be hard-coded into the boot loader image. So, it must be available at compile time, and cannot be migrated to the DT mechanism, but has to be kept in Kconfig. Configuration of this crucial variable should still be somewhat comfortable. Hence, make its fields configurable in Kconfig, and assemble the final value from these. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Get rid of CONFIG_83XX_CLKINMario Six
MPC83xx uses CONFIG_83XX_CLKIN instead of CONFIG_SYS_CLK_FREQ to set the system clock. To migrate the architecture, we can replace CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ. To do this * replace all occurrences of CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ * set CONFIG_SYS_CLK_FREQ to the old value of CONFIG_83XX_CLKIN in all MPC83xx config files Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-20mpc83xx: Make distinct MPC8313ERDB targetsMario Six
MPC8313ERDB has the option of either enabling NOR or NAND boot in its config file (by commenting out certain #ifdefs). To keep this ability after migrating options to Kconfig, we introduce two MPC8313ERDB configs: one for NOR, and one for NAND. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2018-04-08treewide: Migrate CONFIG_TSEC_ENET to KconfigMario Six
Migrate the CONFIG_TSEC_ENET option to Kconfig. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
