path: root/configs/MIP405_defconfig
2017-01-28disk: convert CONFIG_MAC_PARTITION to KconfigPatrick Delaunay
2016-10-23Convert CONFIG_USB_KEYBOARD to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_USB_KEYBOARD Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Fixup MPC86* configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SYS_CONSOLE_OVERWRITE_ROUTINE Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_CONSOLE_EXTRA_INFO to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CONSOLE_EXTRA_INFO Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-10-23Convert CONFIG_VIDEO_CT69000 to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_VIDEO_CT69000 Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
