path: root/configs/MCR3000_defconfig
2019-01-07configs: Resync with savedefconfigTom Rini
2018-12-03board: MCR3000: migrate to DM_SERIALChristophe Leroy
Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2018-12-03board: MCR3000: use new DM watchdogChristophe Leroy
This patch switches MCR3000 board to the new DM watchdog. The change in u-boot.lds is because MCR3000.o grows a bit with this patch and doesn't fit anymore below env_offset on some versions of GCC. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2018-12-03board: MCR3000: Activate CONFIG_DM and CONFIG_OF_CONTROLChristophe Leroy
Add mcr3000 device tree and activate CONFIG_DM and CONFIG_OF_CONTROL Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2018-04-06board: MCR3000: cleanup configChristophe Leroy
Some config is redundant with Kconfig. Fix it. Also remove unused configs Move SDRAM_MAX_SIZE in the only place it is used include/environment.h already defines CONFIG_ENV_SIZE from CONFIG_ENV_SECT_SIZE and defines CONFIG_ENV_ADDR as (CONFIG_SYS_FLASH_BASE + CONFIG_ENV_OFFSET) remove BOOTARGS as bootargs is set by the different boot commands Fix CONFIG_SYS_INIT_RAM_ADDR and CONFIG_SYS_INIT_RAM_SIZE to be in line with CPM DPRAM organisation Remove CONFIG_SYS_GBL_DATA_SIZE, CONFIG_SYS_GBL_DATA_OFFSET and CONFIG_SYS_INIT_SP_OFFSET which are unused Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2018-04-06powerpc: mpc8xx: Change CONFIG_8xx to CONFIG_MPC8xxChristophe Leroy
CONFIG_8xx doesn't mean much outside of arch/powerpc/ This patch renames it CONFIG_MPC8xx just like CONFIG_MPC85xx etc ... It also renames 8xx_immap.h to immap_8xx.h to be consistent with other file names. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
2017-07-25configs: Resync with savedefconfigTom Rini
2017-07-24configs: Migrate RBTREE, LZO, CMD_MTDPARTS, CMD_UBI and CMD_UBIFSTom Rini
The above CONFIG options are in Kconfig, and now have correct depends and inter-dependencies. Migrate these to configs/ from include/configs/. In the case of CMD_UBIFS also change it to be a default y if CMD_UBI. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-07-08powerpc, 8xx: Add support for MCR3000 board from CSSIChristophe Leroy
CS Systemes d'Information (CSSI) manufactures two boards, named MCR3000 and CMPC885 which are respectively based on MPC866 and MPC885 processors. This patch adds support for the first board. Signed-off-by: Christophe Leroy <christophe.leroy@c-s.fr>
