path: root/configs/M5475BFE_defconfig
2020-01-10configs: add eth dm support for all ColdFire boardsAngelo Durgehello
Add dm eth config options for all involved ColdFire-based boards. Signed-off-by: Angelo Durgehello <angelo.dureghello@timesys.com>
2019-05-26configs: Resync with savedefconfigTom Rini
2019-05-24configs: enable use of DT for all m68k boardsAngelo Dureghello
Enable DT usage for all m68k boards. To provide a working single binary, the dts has been kept as embedded. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
