This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
For historical reason, CONFIG_SYS_TEXT_BASE has been specified
in various ways:
[1] by board/${VENDOR}/${BOARD}/config.mk
[2] by CONFIG_SYS_EXTRA_OPTIONS
(This was "options" field of boards.cfg before Kconfig conversion)
[3] by include/configs/${BOARD}.h
[4] by configs/${BOARD}_defconfig
Most of M68K boards use either [1] or [2], both of which we want to
deprecate. Switch them into [4], which is the newest way (Kconfig).
We still allow [3] too, because it is still used by many boards and
we expect much time for conversion.
Acked-by: Angelo Dureghello <angelo at sysam.it>
There are already Kconfig options for SPI flash drivers, but we
have not moved them from config.h to defconfig files. This commit
does this in a batch.
them from include/configs.
Some archs/boards specify their own default by pre-defining the config
which causes the Kconfig system to mix up the order of the configs in
the defconfigs... This will cause merge pain if allowed to proliferate.
Remove the configs that behave this way from the archs.
A few configs still remain, but that is because they only exist as
defaults and do not have a proper Kconfig entry. Those appear to be:
SPIFLASH
DISPLAY_BOARDINFO
[trini: rastaban, am43xx_evm_usbhost_boot, am43xx_evm_ethboot updates,
drop DM_USB from MSI_Primo81 as USB_MUSB_SUNXI isn't converted yet to DM]
This also selects CONFIG_NET for any CONFIG_CMD_NET board.
Remove the imx default for CONFIG_NET.
This moves the config that was defined by 60296a8 (commands: add more
command entries in Kconfig).
In order to reduce merge conflicts and to maintain the simplest possible
defconfig files, we should be using the savedefconfig feature of Kconfig
every time a new feature is added. This keeps the defconfig settings to
a minimum (only those things not default) and keeps them in the same
order as the Kconfig options.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
