path: root/configs/M54451EVB_stmicro_defconfig
2019-05-26configs: Resync with savedefconfigTom Rini
2019-05-24configs: add DM_SPI config optionAngelo Dureghello
This patch adds CONFIG_DM_SPI for all m68k boards using the cf_spi.c driver (DSPI module). Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2019-05-24configs: enable use of DT for all m68k boardsAngelo Dureghello
Enable DT usage for all m68k boards. To provide a working single binary, the dts has been kept as embedded. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2019-03-25Convert CONFIG_ENV_SPI_* to KconfigPatrick Delaunay
This converts the following to Kconfig: CONFIG_ENV_SPI_BUS CONFIG_ENV_SPI_CS CONFIG_ENV_SPI_MAX_HZ CONFIG_ENV_SPI_MODE Most of time these value are not needed, CONFIG_SF_DEFAULT with same value is used, so I introduced CONFIG_USE_ENV_SPI_* to force the associated value for the environment. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-02-13spi: Migrate CONFIG_CF_SPI to KconfigTuomas Tynkkynen
