path: root/configs/M5275EVB_defconfig
2019-05-26configs: Resync with savedefconfigTom Rini
2019-05-24configs: enable use of DT for all m68k boardsAngelo Dureghello
Enable DT usage for all m68k boards. To provide a working single binary, the dts has been kept as embedded. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
