CONFIG_MCFUART
CONFIG_SYS_MALLOC_LEN
Acked-by: Sean Anderson <seanga2@gmail.com>
Reviewed-by: Rick Chen <rick@andestech.com>
Now that we have consistent usage, migrate this symbol to Kconfig.
CONFIG_SYS_DEVICE_NULLDEV
Both CMD_MX_CYCLIC and MX_CYCLIC are in use and defined in Kconfig,
but only the non-CMD version currently does anything. This changes all
usages to prefer the CMD_MX_CYCLIC option (since it's only affecting
addition of the commands), and switches defconfigs using the non-CMD
version to use the CMD version.
Signed-off-by: Joel Johnson <mrjoel@lixil.net>
to 0.
SYS_REDUNDAND_ENVIRONMENT
ENV_IS_IN_FLASH.
- Migrate all platforms.
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_MX_CYCLIC
Acked-by: David Lechner <david@lechnology.com>
Enable DT usage for all m68k boards. To provide a
working single binary, the dts has been kept as embedded.
Signed-off-by: Angelo Dureghello <angelo@sysam.it>
CONFIG_FLASH_CFI_DRIVER
CONFIG_SYS_FLASH_USE_BUFFER_WRITE
CONFIG_FLASH_CFI_MTD
CONFIG_SYS_FLASH_PROTECTION
CONFIG_SYS_FLASH_CFI
[trini: Re-migrate]
Enable networking command only when NET is enabled.
And remove selecting NET for CMD_NET
CONFIG_BOOTP_BOOTPATH
CONFIG_BOOTP_DNS
CONFIG_BOOTP_GATEWAY
CONFIG_BOOTP_HOSTNAME
CONFIG_BOOTP_PXE
CONFIG_BOOTP_SUBNETMASK
CONFIG_CMDLINE_EDITING
CONFIG_AUTO_COMPLETE
CONFIG_SYS_LONGHELP
CONFIG_SUPPORT_RAW_INITRD
CONFIG_ENV_VARS_UBOOT_CONFIG
[trini: Re-run the migration]
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
We repeated partial moves for CONFIG_SYS_NO_FLASH, but this is
not completed. Finish this work by the tool.
During this move, let's rename it to CONFIG_MTD_NOR_FLASH.
Actually, we have more instances of "#ifndef CONFIG_SYS_NO_FLASH"
than those of "#ifdef CONFIG_SYS_NO_FLASH". Flipping the logic will
make the code more readable. Besides, negative meaning symbols do
not fit in obj-$(CONFIG_...) style Makefiles.
This commit was created as follows:
[1] Edit "default n" to "default y" in the config entry in
common/Kconfig.
[2] Run "tools/moveconfig.py -y -r HEAD SYS_NO_FLASH"
[3] Rename the instances in defconfigs by the following:
find . -path './configs/*_defconfig' | xargs sed -i \
-e '/CONFIG_SYS_NO_FLASH=y/d' \
-e 's/# CONFIG_SYS_NO_FLASH is not set/CONFIG_MTD_NOR_FLASH=y/'
[4] Change the conditionals by the following:
find . -name '*.[ch]' | xargs sed -i \
-e 's/ifndef CONFIG_SYS_NO_FLASH/ifdef CONFIG_MTD_NOR_FLASH/' \
-e 's/ifdef CONFIG_SYS_NO_FLASH/ifndef CONFIG_MTD_NOR_FLASH/' \
-e 's/!defined(CONFIG_SYS_NO_FLASH)/defined(CONFIG_MTD_NOR_FLASH)/' \
-e 's/defined(CONFIG_SYS_NO_FLASH)/!defined(CONFIG_MTD_NOR_FLASH)/'
[5] Modify the following manually
- Rename the rest of instances
- Remove the description from README
- Create the new Kconfig entry in drivers/mtd/Kconfig
- Remove the old Kconfig entry from common/Kconfig
- Remove the garbage comments from include/configs/*.h
CONFIG_SYS_CONSOLE_INFO_QUIET
[trini: Make this default n, re-run the migration]
Create a Kconfig entry for DISPLAY_BOARDINFO and make it be the default
in certain architectures. Migrate all config files.
Since commit bb597c0eeb7e ("common: bootdelay: move CONFIG_BOOTDELAY
into a Kconfig option"), CONFIG_BOOTDELAY is defined for all boards.
Prior to that commit, it was allowed to unset CONFIG_BOOTDELAY to
not compile common/autoboot.c, as described in common/Makefile:
# This option is not just y/n - it can have a numeric value
ifdef CONFIG_BOOTDELAY
obj-y += autoboot.o
endif
It was a bit odd to enable/disable code with an integer type option,
but it was how this option worked before that commit, and several
boards actually unset it to opt out of the autoboot feature.
This commit adds a new bool option, CONFIG_AUTOBOOT, and makes
CONFIG_BOOTDELAY depend on it.
I chose "default y" for this option because most boards use the
autoboot. I added "# CONFIG_AUTOBOOT is not set" for the boards that
had not set CONFIG_BOOTDELAY prior to the bad commit.
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
For historical reason, CONFIG_SYS_TEXT_BASE has been specified
in various ways:
[1] by board/${VENDOR}/${BOARD}/config.mk
[2] by CONFIG_SYS_EXTRA_OPTIONS
(This was "options" field of boards.cfg before Kconfig conversion)
[3] by include/configs/${BOARD}.h
[4] by configs/${BOARD}_defconfig
Most of M68K boards use either [1] or [2], both of which we want to
deprecate. Switch them into [4], which is the newest way (Kconfig).
We still allow [3] too, because it is still used by many boards and
we expect much time for conversion.
Acked-by: Angelo Dureghello <angelo at sysam.it>
them from include/configs.
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
