path: root/configs/Linksprite_pcDuino_defconfig
2015-10-20sunxi: Kconfig-ify CONFIG_AXP152_POWER and _AXP209_POWERHans de Goede
Kconfig-ify CONFIG_AXP152_POWER and _AXP209_POWER settings, removing them from CONFIG_SYS_EXTRA_OPTIONS. Note that sun5i boards can have either an AXP209 or an AXP152 pmic, the Kconfig default is AXP209, boards with an AXP152 must explicitly select this. Likewise boards without a pmic must explicitly select SUNXI_NO_PMIC in their defconfig. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-10-10sunxi: Fix USB regulators in Linksprite_pcDuino_defconfigSiarhei Siamashka
The pcDuino1 board unconditionally provides 5V to USB host receptacles. The pcDuino2 board has a voltage regulator, controlled by the PD2 pin which is pulled-up by default (so that the USB power is also enabled by default). Not specifying pins for enabling USB power in the defconfig means that the PH3 and PH6 pins are driven high by default. The PH6 pin is available on the Arduino-compatible expansion header and touching it is not nice (this may be even dangerous, depending on what kind of role is assigned to this particular pin by various Arduino shields). This patch explicitly configures the USB VBUS pins to "", which means that no pins should be touched. The patch has been tested on a pcDuino2 board and USB still works. Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-10-10sunxi: Fix pcDuino reliability by downclocking DRAM to 360MHzSiarhei Siamashka
Linksprite_pcDuino_defconfig is a generic config for pcDuino1 and pcDuino2 boards. The pcDuino2 board exists at least in two variants (with DDR3 chips from HYNIX or NANYA). At least one pcDuino2 board with HYNIX DDR3 fails the lima-memtester reliability test unless the DRAM clock speed is reduced to 360MHz. A detailed analysis report, generated by the a10-tpr3-scan tool with the explanations why the DRAM is failing at 408MHz, is available at: http://linux-sunxi.org/index.php?title=User:Ssvb/pcDuino2_with_HYNIX_DDR3_reliability_test&oldid=15152 http://web.archive.org/web/20151008190210/http://linux-sunxi.org/User:Ssvb/pcDuino2_with_HYNIX_DDR3_reliability_test Signed-off-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-22sunxi: Remove CONFIG_TARGET_FOO for sun4i, sun6i and sun8i boardsHans de Goede
CONFIG_TARGET_FOO is only used in board/sunxi/Makefile to select the dram config for sun5i and sun7i boards and in board/sunxi/gmac.c for some special handling of the bananapi/bananapro (both sun7i), iow it is not used at all on any sun4i, sun6i and sun8i boards so lets get rid of it there. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-22sunxi: Convert sun4i boards to use auto dram configurationHans de Goede
Currently we've separate detailed dram settings for all sun4i boards, this moves them over to using auto dram configuration so that we can get rid of all the per board dram_foo.c files. Tested-by: Hans de Goede <hdegoede@redhat.com> on a A10-OLinuXino-Lime, Chuwi_V7_CW0825 and ba10_tv_box Tested-by: Zoltan HERPAI <wigyori@uid0.hu> on a pcduino Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: add Linksprite pcDuino v1/v2 supportZoltan HERPAI
Add support for a sun4i board built by Linksprite. This addition covers both v1 and v2 versions. As the board has been working with 408MHz memory setting in the u-boot-sunxi branch, and has been proven to be running stable during my tests as well, a respective new DRAM config file is added as well. Signed-off-by: Zoltan HERPAI <wigyori@uid0.hu> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
