path: root/configs/Linksprite_pcDuino3_Nano_defconfig
2016-05-25sunxi: Enable a bunch of commands by default on sunxiHans de Goede
Recently a set of CONFIG_CMD_FOO defines was moved from being defined in config_distro_defaults to Kconfig, and added to all sunxi defconfigs to compensate. Instead of explictly selecting these in all sunxi defconfigs, simply always select these for sunxi boards. This makes the defconfigs simpler and ensures a consistent set of available commands across all sunxi boards. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-04-12sunxi: Enable CMD_GPIO on all sunxi boardsHans de Goede
We have CONFIG_CMD_GPIO=y in almost all sunxi boards, but after its Kconfig conversion it has ended up missing on some recently added boards. Simply select it for ARCH_SUNXI, so that we get it on all sunxi boards for both a consistent user experience and simpler defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-03-23sunxi: Select CONFIG_OF_BOARD_SETUP from arch/arm/KconfigHans de Goede
Always select OF_BOARD_SETUP on sunxi, rather then having it in almost all our defconfigs. This also fixes it missing from some recently added defconfigs. This commit also modifies our ft_board_setup() to not cause warnings when CONFIG_VIDEO_DT_SIMPLEFB is not set, since we will now always build it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-12-10sunxi: select SYS_NS16550 from KconfigHans de Goede
Select SYS_NS16550 from Kconfig instead of setting it in all our defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-10-20sunxi: Kconfig-ify CONFIG_AXP152_POWER and _AXP209_POWERHans de Goede
Kconfig-ify CONFIG_AXP152_POWER and _AXP209_POWER settings, removing them from CONFIG_SYS_EXTRA_OPTIONS. Note that sun5i boards can have either an AXP209 or an AXP152 pmic, the Kconfig default is AXP209, boards with an AXP152 must explicitly select this. Likewise boards without a pmic must explicitly select SUNXI_NO_PMIC in their defconfig. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-05-04sunxi: Move all boards to the driver-modelHans de Goede
Now that we've everything prepared for it remove the DM settings from the defconfig(s) and simply always set them for sunxi. This makes all sunxi boards allways use the driver model for gpios and ethernet, and allows us to move over more bits to the driver-model without the need to introduce #ifdef-ery for boards which are not yet using DM. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-04-18Kconfig: Move CONFIG_DESIGNWARE_ETH to KconfigSimon Glass
Move this to Kconfig and clean up board config files that use it. Also rename it to CONFIG_ETH_DESIGNWARE to fit with the naming that exists in drivers/net/Kconfig. Signed-off-by: Simon Glass <sjg@chromium.org> Version 1: Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2015-02-02sunxi: Add Linksprite_pcDuino3_Nano board / defconfigAdam Sampson
This is a low-cost Allwinner A20 board with Arduino-style GPIO headers; it features 1G RAM, 4G NAND flash, 1 micro-SD, 2 USB sockets, 1 micro USB socket for OTG and another for power in, HDMI, SATA, 5V power for SATA devices, gigabit Ethernet, an IR receiver, 3.5mm audio out and a MIPI camera connector. Like the BananaPi, this board needs GMAC_TX_DELAY set to 3 in order for GMAC to work reliably at gigabit speeds. For more details, see: http://linux-sunxi.org/LinkSprite_pcDuino3_Nano Signed-off-by: Adam Sampson <ats@offog.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
