When some configuration symbols were converted from header files to
Kconfig, their values were placed into *every* defconfig file.
Since we now have sensible per-SoC defaults defined in Kconfig, those
values are now redundant, and can just be removed.
This affects CONFIG_SPL_STACK, CONFIG_SYS_PBSIZE, CONFIG_SPL_MAX_SIZE,
and CONFIG_SYS_BOOTM_LEN.
Signed-off-by: Andre Przywara <andre.przywara@arm.com>
CONFIG_LBA48
CONFIG_SYS_64BIT_LBA
CONFIG_SPL_STACK
CONFIG_SYS_PBSIZE
CONFIG_SYS_I2C_SPEED
CONFIG_SYS_I2C_SLAVE
CONFIG_SYS_I2C_MVTWSI
Rename these options so that CONFIG_IS_ENABLED can be used with them.
CONFIG_PHYLIB
CONFIG_BITBANGMII
CONFIG_MV88E6352_SWITCH
CONFIG_MV88E61XX_SWITCH
CONFIG_PHYLIB_10G
CONFIG_PHY_AQUANTIA
CONFIG_PHY_ATHEROS
CONFIG_PHY_BROADCOM
CONFIG_PHY_CORTINA
CONFIG_PHY_DAVICOM
CONFIG_PHY_ET1011C
CONFIG_PHY_LXT
CONFIG_PHY_MARVELL
CONFIG_PHY_MICREL
CONFIG_PHY_NATSEMI
CONFIG_PHY_REALTEK
CONFIG_RTL8211X_PHY_FORCE_MASTER
CONFIG_PHY_SMSC
CONFIG_PHY_TERANETICS
CONFIG_PHY_TI
CONFIG_PHY_VITESSE
CONFIG_PHY_XILINX
Now that those common Allwinner config symbols are defined automatically
for all boards in their Kconfig files, we can remove the now redundant
definitions from the boards' _defconfig files.
Some boards had a differing definiton for some of those symbols, it
looks like mostly to "merge races" when the symbol was introduced (new
board *_defconfig file missed the "add symbol to all files" patch).
Acked-by: Maxime Ripard <mripard@kernel.org>
Tested-by: Jagan Teki <jagan@amarulasolutions.com> # Amarula A64-Relic
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Today in initr_reloc_global_data() we use some non-obvious tests to
determine if we need to relocate the env_addr within gd or not. In
order to facilitate migration of other symbols to Kconfig we need to
introduce a new symbol for this particular use case.
CONFIG_USE_PREBOOT
CONFIG_PREBOOT
Both are together in one commit, since otherwise the former causes kconfig
to define the latter, which gives duplicate symbol errors.
Includes a manual fixup for CONFIG_PREBOOT in ids8313_defconfig since the
backslash lands in the wrong place. Similarly with socfpga_vining_fpga.
The choice of the SPL_TEXT_BASE is not really a decision that should be
specified by each board's defconfig, as this setting is actually
dictated by the SoC's memory map and the BootROM behaviour.
To make this obvious and reduce the clutter in the defconfig files,
let's specify the SoC constraints in the Kconfig stanza.
This allows us to remove these lines from the defconfig files again.
Acked-by: Maxime Ripard <maxime.ripard@bootlin.com>
Moved CONFIG_SPL_TEXT_BASE to common/spl/Kconfig and migrate existing
values.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
[trini: Re-run migration]
Onc of key blocker for using USB Generic host controller
drivers in Allwinner are CLK and RESET drivers, now these
available for USB usage.
So switch sunxi USB use EHCI and OHCI Generic controllers.
Enabling USB is wisely a board choise, So Enable USB_OHCI_HCD
where it already have USB_EHCI_HCD
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
CONFIG_MII
CONFIG_DRIVER_TI_EMAC
Acked-by: Jagan Teki <jagan@amarulasolutions.com>
We have the following cases:
- CONFIG_NR_DRAM_BANKS was defined, migrate normally
- CONFIG_NR_DRAM_BANKS_MAX was defined and then used for
CONFIG_NR_DRAM_BANKS after a check, just migrate it over now.
- CONFIG_NR_DRAM_BANKS was very oddly defined on p2771-0000-* (to 1024 +
2), set this to 8.
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot
could load distro images that usually get shipped as iso images. These images
usually come with a board agnostic boot environment.
However, there is very little point in having ISO support enabled (for anyone
really) in SPL, as the whole idea of SPL is to load U-Boot proper which again
is board specific. So the fact that we enable ISO support in U-Boot proper does
not mean at all that we want ISO support in U-Boot SPL.
Hence, let's remove the Kconfig dependency. Along the way, let's also clean up
all those default configs that disabled SPL ISO support.
Commit 278b90ce786f ("configs: Migrate CONFIG_SYS_TEXT_BASE") made
CONFIG_SYS_TEXT_BASE a proper Kconfig variable, with the consequence
of moving the common definition shared by almost every sunxi board
into 123 individual defconfig files. But the U-Boot start address
for Allwinner boards is a platform decision which has been around for
ages, so defining it in each *board* config file seems a bit over the
top.
Define the standard values (160MB into DRAM for most SoCs, with two
SoC exceptions) if ARCH_SUNXI is selected, and delete the lines from
the individual defconfigs.
Reviewed-by: Jagan Teki <jagan@openedev.com>
On the NIOS2 and Xtensa architectures, we do not have
CONFIG_SYS_TEXT_BASE set. This is a strict migration of the current
values into the defconfig and removing them from the headers.
I did not attempt to add more default values in and for now will leave
that to maintainers.
cmd/Makefile has:
ifdef CONFIG_FPGA
obj-$(CONFIG_CMD_FPGA) += fpga.o
endif
which means that if CONFIG_FPGA is not set, CONFIG_CMD_FPGA silently
does nothing. Let's remove that Makefile conditional and instead express
this equivalent dependency in Kconfig, so a lot of redundant
# CONFIG_CMD_FPGA is not set
can be removed from board defconfigs that don't actually have an FPGA.
Enable CONFIG_B53_SWITCH, define the CPU/management port number (8) and
enable all 5 ports of the switch to be usable.
Signed-off-by: Florian Fainelli <f.fainelli@gmail.com>
And use 'imply' liberally.
Having this as a 'default y' is rather annoying because it doesn't
actually compile unless other options are defined in the board header:
../cmd/bootm.c: In function 'do_imls_nor':
../cmd/bootm.c:330:7: error: 'CONFIG_SYS_MAX_FLASH_BANKS' undeclared (first use in this function); did you mean 'CONFIG_SYS_MAX_FLASH_SECT'?
i < CONFIG_SYS_MAX_FLASH_BANKS; ++i, ++info) {
Make it 'default n' so people who develop new boards that start from a
blank defconfig have one less compilation failure to debug.
This syncs all of the currently Kconfig'd symbols out of the headers and
into the defconfig files. This has two exceptions, first am335x_evm
needs to be converted to DM in SPL and then it can stop undef'ing
CONFIG_DM_USB. Leaving this as-is results in a build failure, and
without work, run time failure. The other case is am43xx_evm.h and in
turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB
host mode in SPL, but still desire to have gadget mode in U-Boot proper.
CONFIG_SCSI
Convert the CONFIG_MACPWR to Kconfig and update all the sunxi defconfigs
that used it in SYS_EXTRA_OPTIONS.
Signed-off-by: Mylène Josserand <mylene.josserand@free-electrons.com>
Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
Convert the CONFIG_SATAPWR into kconfig.
Thanks to that, many SYS_EXTRA_OPTIONS can be removed from some
defconfigs.
Convert CONFIG_RGMII to Kconfig. Thanks to that, it is possible to
update defconfig files of SYS_EXTRA_OPTIONS accordingly and
remove it when it is possible.
Move the SUNXI_GMAC config option to Kconfig, remove it
from SYS_EXTRA_OPTIONS and rename it into SUN7I_GMAC.
Signed-off-by: Patrick Delaunay <patrick.delaunay73@gmail.com>
Generated by "tools/moveconfig -s".
This will make config moves easier.
Use the already available Kconfig option for AHCI. Tested on the
BananaPi.
Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
Move this option to Kconfig and tidy up existing uses.
Move the SPL settings into common/spl where most of the SPL code is kept.
Recently a set of CONFIG_CMD_FOO defines was moved from being defined
in config_distro_defaults to Kconfig, and added to all sunxi defconfigs
to compensate.
Instead of explictly selecting these in all sunxi defconfigs,
simply always select these for sunxi boards. This makes the defconfigs
simpler and ensures a consistent set of available commands across all
sunxi boards.
Update the config.h and defconfig files for the commands that 8e3c036
converted over to Kconfig
This syncs up the current cmd/Kconfig and include/configs/ files with the
only exception being CMD_NAND. Due to how we have used this historically
we need to take further care here when converting.
