path: root/configs/Itead_Ibox_A20_defconfig
2018-04-16part: Disable CONFIG_SPL_ISO_PARTITION by defaultAlexander Graf
We enabled CONFIG_ISO_PARTITION by default for distro boot, so that U-Boot could load distro images that usually get shipped as iso images. These images usually come with a board agnostic boot environment. However, there is very little point in having ISO support enabled (for anyone really) in SPL, as the whole idea of SPL is to load U-Boot proper which again is board specific. So the fact that we enable ISO support in U-Boot proper does not mean at all that we want ISO support in U-Boot SPL. Hence, let's remove the Kconfig dependency. Along the way, let's also clean up all those default configs that disabled SPL ISO support. Signed-off-by: Alexander Graf <agraf@suse.de>
2018-03-14sunxi: move CONFIG_SYS_TEXT_BASE out of defconfigsAndre Przywara
Commit 278b90ce786f ("configs: Migrate CONFIG_SYS_TEXT_BASE") made CONFIG_SYS_TEXT_BASE a proper Kconfig variable, with the consequence of moving the common definition shared by almost every sunxi board into 123 individual defconfig files. But the U-Boot start address for Allwinner boards is a platform decision which has been around for ages, so defining it in each *board* config file seems a bit over the top. Define the standard values (160MB into DRAM for most SoCs, with two SoC exceptions) if ARCH_SUNXI is selected, and delete the lines from the individual defconfigs. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@bootlin.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-12-12ata: Migrate CONFIG_SCSI_AHCI to KconfigTuomas Tynkkynen
And use 'imply' liberally. Signed-off-by: Tuomas Tynkkynen <tuomas.tynkkynen@iki.fi>
2017-09-01configs: Migrate all of the existing USB symbols, except fastbootTom Rini
This syncs all of the currently Kconfig'd symbols out of the headers and into the defconfig files. This has two exceptions, first am335x_evm needs to be converted to DM in SPL and then it can stop undef'ing CONFIG_DM_USB. Leaving this as-is results in a build failure, and without work, run time failure. The other case is am43xx_evm.h and in turn am43xx_evm_usbhost_boot. The problem here is that we need DWC3 USB host mode in SPL, but still desire to have gadget mode in U-Boot proper. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-11configs: Resync with savedefconfigTom Rini
2017-07-11Convert CONFIG_SCSI to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_SCSI Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2017-04-20sunxi: Convert CONFIG_SATAPWR to KconfigMylène Josserand
Convert the CONFIG_SATAPWR into kconfig. Thanks to that, many SYS_EXTRA_OPTIONS can be removed from some defconfigs. Signed-off-by: Mylène Josserand <mylene.josserand@free-electrons.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Move SUNXI_GMAC to KconfigMylène Josserand
Move the SUNXI_GMAC config option to Kconfig, remove it from SYS_EXTRA_OPTIONS and rename it into SUN7I_GMAC. Signed-off-by: Mylène Josserand <mylene.josserand@free-electrons.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2016-11-28sunxi: Use the available Kconfig option for AHCIJelle van der Waa
Use the already available Kconfig option for AHCI. Tested on the BananaPi. Signed-off-by: Jelle van der Waa <jelle@vdwaa.nl> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-05-25sunxi: Enable a bunch of commands by default on sunxiHans de Goede
Recently a set of CONFIG_CMD_FOO defines was moved from being defined in config_distro_defaults to Kconfig, and added to all sunxi defconfigs to compensate. Instead of explictly selecting these in all sunxi defconfigs, simply always select these for sunxi boards. This makes the defconfigs simpler and ensures a consistent set of available commands across all sunxi boards. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-04-12sunxi: Enable CMD_GPIO on all sunxi boardsHans de Goede
We have CONFIG_CMD_GPIO=y in almost all sunxi boards, but after its Kconfig conversion it has ended up missing on some recently added boards. Simply select it for ARCH_SUNXI, so that we get it on all sunxi boards for both a consistent user experience and simpler defconfig files. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-03-23sun7i: Add defconfig for the Itead IboxMarcus Cooper
Add defconfig for the multi board device based on the Allwinner A20 SoC. It contains the A20 Itead Core module and a base board for the external interfaces. The core module comes with 4GB NAND and 1GB DDR RAM. The base board to which the core board is connected provides 3 USB 2.0 Host ports, 1 USB 2.0 OTG, 1 uSD slot, 10/100 Ethernet port, HDMI, IR receiver, SPDIF and a 32-pin GPIO header. This header expands the features of core board by exposing the VGA pins, audio In/Out pins, SATA, SPI, I2C, UARTS, USB-OTG and power.. Signed-off-by: Marcus Cooper <codekipper@gmail.com> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
