path: root/configs/Ippo_q8h_v5_defconfig
2015-03-10sunxi: Ippo_q8h defconfigs: Enable otg vbus detection using AXP223 PMICChen-Yu Tsai
Use the AXP223 PMIC to detect VBUS for musb otg support. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-02-02sunxi: Remove CONFIG_TARGET_FOO for sun5i and sun7i boardsHans de Goede
CONFIG_TARGET_FOO was only used in board/sunxi/Makefile to select the dram config for sun5i and sun7i boards and in board/sunxi/gmac.c for some special handling of the bananapi/bananapro (both sun7i), all sun5i and sun7i boards have been moved over to using a single dram_sun5i_autoconfig file, and the tx clk delay handling for the Banana boards now has its own Kconfig. IOW nothing is using CONFIG_TARGET_FOO anymore, so remove it. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-22sunxi: Hookup OTG USB controller supportHans de Goede
Hookup OTG USB controller support and enable the otg controller + USB-keyb on various tablets. This allows tablet owners to interact with u-boot without needing to solder a serial console onto their tablet PCB. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-22sunxi: display: Make lcd display clk phase configurableHans de Goede
While running some tests with an Olinuxino-A13-Micro + a 7" Olimex LCD module I noticed that the screen flickered. This is caused by the lcd display clk phase reg value being set to 0, where it should be 1 in this setup. This commit adds a Kconfig option for the lcd display clk phase, so that we can set it per board. This defaults to 1, because looking at all the fex files in sunxi-boards, that is by far the most used value. This commit updated the Ippo and MSI Primo73 tablet defconfigs to override the default of 1 with 0, as that is the correct value for those tablets, this keeps the register settings the same as before this commit. The Olinuxino-A13 defconfigs are not updated, changing the register setting for these boards from 0 to 1, this is intentional. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-01-14sunxi: Ippo_q8h defconfigs: Enable the LCD panel found on these tablets.Hans de Goede
Enable the new LCD support on Ippo_q8h tablets. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk> Tested-by: Chen-Yu Tsai <wens@csie.org>
2015-01-14sun8i: Ippo_q8h_v5_defconfig: Enable SPL supportHans de Goede
Now that we've sun8i dram-init support we can enable the SPL for sun8i boards. While at it also replace CONFIG_DEFAULT_DEVICE_TREE with CONFIG_FDTFILE, the former is for u-boot's own fdt usage, which we do not use (yet), the later specifies the fdt to pass to the kernel, which is the one we want. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-25sunxi: Add usb keyboard Kconfig optionHans de Goede
For use together with the hdmi console. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ian.campbell@citrix.com>
2014-11-25sunxi: video: Add cfb console driver for sunxiLuc Verhaegen
This adds a fixed mode hdmi driver for the sunxi platform. The fixed mode is a relatively safe 1024x768, more complete EDID handling is currently not provided. Only HDMI is supported today. This code is enabled when HPD detects an attached monitor. Current config is such that 8MB is shaved off at the top of the RAM. This avoids several memory handling issues, most significant is the fact that on linux on ARM you are not allowed to remap known RAM as IO. A clued in display driver will be able to recycle this reserved RAM in future though. cfbconsole was chosen as it provides the most important functionality: a working u-boot console, allowing for the debugging of certain issues without the need for a UART. Signed-off-by: Luc Verhaegen <libv@skynet.be> [hdegoede@redhat.com: Major cleanups and some small bugfixes] Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Anatolij Gustschin <agust@denx.de> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2014-11-05sunxi: kconfig: Introduce CONFIG_TARGET_<BOARD>Ian Campbell
This was done automatically with the following bits of scripting. The Kconfig choice content was generated with this script snippet: for i in $(git grep -l CONFIG_ARCH_SUNXI configs/*) ; do TARGET=$(sed -n -e 's/CONFIG_SYS_EXTRA_OPTIONS="\([^,"]\+\).*/\1/p' $i); MACH=$(sed -n -e 's/.*CONFIG_\(MACH_SUN.I\)=./\1/p' $i) echo "config TARGET_$TARGET" echo " bool \"$TARGET\"" echo " depends on $MACH" echo done defconfigs were updated with a sed script (t): # Extract board from first entry of CONFIG_SYS_EXTRA_OPTIONS, /^CONFIG_SYS_EXTRA_OPTIONS/ { s/^\(CONFIG_SYS_EXTRA_OPTIONS="\)\([^,"]\+\),\?\(.*\)/\1\3\nCONFIG_TARGET_\2=y/; # Print and delete first line (CONFIG_SYS_EXTRA_OPTIONS), leaving # CONFIG_TARGET_<BOARD> in pattern space P;D; }; # Move CONFIG_TARGET_<BOARD> to hold space /^CONFIG_TARGET/{h;n} # Print CONFIG_TARGET_<BOARD> after CONFIG_MACH_<SOC> in either SPL or # normal mode. /^CONFIG_MACH/{p;g;p;n}; /^\+S:CONFIG_MACH/{p;g;s/^CONFIG_TARGET/+S:&/;p;n}; # Print any remaining lines normally p; Run as: sed -i -n -f t $(git grep -l CONFIG_ARCH_SUNXI configs/*) and then manually removing the one instance of CONFIG_SYS_EXTRA_OPTIONS="" from Colombus_defconfig board/sunxi/Makefile was updated with: sed -e 's/^\(obj-\$(CONFIG_\)\(.*\)\().*+= dram_.*\)/\1TARGET_\2\3/g' board/sunxi/Makefile and manually retabbing a few lines to line up again. The board descriptions could certainly be improved. Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05sunxi: kconfig: Rename TARGET_SUN[45678]I to MACH_SUN[45678]I.Ian Campbell
Now we have CONFIG_ARCH_SUNXI as the toplevel, CONFIG_MACH_SUN[45678]I as the per-SoC option and leave CONFIG_TARGET_BLAH free for individual boards in the future. Done automatically with: sed -i -e 's/TARGET_\(SUN[45678]I\)/MACH_\1/g' $(git grep -l TARGET_SUN[45678]I) Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05sunxi: kconfig: Add top-level ARCH_SUNXIIan Campbell
And make TARGET_SUN[45678]I a choice variable under this. configs updated with: sed -i -e 's/^\(\+S:\)\?CONFIG_TARGET_SUN.I=y/\1CONFIG_ARCH_SUNXI=y\n&/g' configs/* Signed-off-by: Ian Campbell <ijc@hellion.org.uk> Reviewed-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2014-11-05ARM: sunxi: Fix Ippo-q8h-v5 defconfig filenameChen-Yu Tsai
The defconfig for Ippo-q8h-v5 was incorrectly committed as "Ippo_q8h". This patch renames it correctly, as well as correct a typo in my name in the maintainers listing. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Hans de Goede <hdegoede@redhat.com> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
