path: root/configs/IVMS8_256_defconfig
2015-01-05mpc8xx: remove IVMS8, IVML24 board supportMasahiro Yamada
This board is still a non-generic board. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de>
