path: root/configs/Hyundai_A7HD_defconfig
2015-08-21Tidy up some defconfig filesSimon Glass
Several files are out of order. This means that when the moveconfig tool moves CONFIG options to Kconfig it generates a large diff. To avoid this, reorder the files first. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-08-05sunxi: usb: USB_MUSB_SUNXI move to musb-new KconfigPaul Kocialkowski
Now that the musb-new driver has a Kconfig, we can move Kconfig options to enable controllers to it, so that it's easier in e.g. menuconfig. In addition, this allows declaring support for USB_MUSB_HOST/GADGET in defconfigs instead of the USB_MUSB_SUNXI controller, that will get selected automatically when needed. Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
2015-02-21sunxi: musb: Check Vbus-det before enabling otg port powerHans de Goede
Sending out 5V when there is a charger connected to the otg port is not a good idea, so check for this and error out. Note this commit currently breaks otg support on the q8h tablets, as we need to do some magic with the pmic there to get vbus info, this is deliberate (better safe then sorry), fixing this is on my TODO list. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2015-02-02sunxi: Hyundai_A7HD_defconfig fix USB vbus pin configHans de Goede
USB1_VBUS is not used, and USB2_VBUS uses the pin normally used to control USB1_VBUS. Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-01-23sunxi: Add Hyundai A7HD supportHans de Goede
The Hyundai A7HD is a 7" 16:9 A10 powered tablet featuring 1G RAM, 8G nand, 1024x600 IPS screen, a mini hdmi port, mini usb receptacle and a headphones port for details see: http://linux-sunxi.org/Hyundai_A7HD Cc: Mark Janssen <maniac@maniac.nl> Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
